Kenmore 70 series top load washer - no spin
Our washer will not spin anymore. Sounds like the motor is running, but it will not spin......Any suggestions/thoughts?
  • 156 Answers
The older belt drive washer has a cylanoid under it on the top trans missin called a wig wag eather broken wire to it are bad wig wag can still be found ck lid switch also
Posted on Mar 19, 2008
Spinner will not spin
have kenmore 70 series washer model: 110.7015626w that will agitate but sluggishly and will not spin but the belt is getting hot (drum is not spinning but the motor is running).
Dec 17, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Apr 28, 2009 | Kenmore 23822 Top Load Washer
My kenmore top loading washer 70 series wont go into spin cycle
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
Apr 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer not spinning ans washing
Does it sound like the motor is running at all ?( if motor is running u need a coupler) (with machine off turn cycle switch around 3x roughly, then try machine) With the machine off do you hear a clicking noise if you open and close the lid?
Mar 25, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 70 series 20702 will not spin or drain
it sounds like your coupler is broken, with the machine unplugged and with help pull the washer out and then tilt it back. look between the motor and the transmition for a back disk sandwiched between 2 white disks. if it is gone then you need to replace the coupler. it is a medium difficulty job, you need to take the shell off in order to do the job.
Dec 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
163 people viewed this question
Top Washing Machines Experts
