Question about Acer Aspire 3000 Notebook
Frezzing computer 4 weeks ago i had new ram installed into my acer3000 a few days after then i started to have a problem with it frezzing everything would appear to be running but my curser will not move i have had it back to the shop that i bought the ram from and so fare he has replaced the hard drive and pcu and this morning tells me it needs a new battery i can not understand how a system can be working then it just stops i under stand if it was a very old system but being only 2 and half to 3 years i do not consider this to be an old systen maybe outdated but not old are you able to give me any sagestions on what i can do with this system or what could be causing the problem the solution is not to purchase a new one as i dont have the funds but need to find a away to fix i do not beleive it is the mother board as the repaire man said that his tests showed the mother board working ok can you help thanks michael
    Genius:
  • 1,226 Answers
Hello!
You know Michael, Once your computer freeze this causes is these.
1. Present of virus in the system
2. Hard drive damage
3. Memory mismatch
..solution:
1. be sure to scan with a potent antivirus if not work, format reinstall the windows
2. If you do number one and still freeze then verify the memory and the hard drive.
In your case the problem started when you insert memory i guess it was mismatch memory.
guidelines for memory:
Do not use two different capacity memory in the computer.
it should be thesame manufacture date if possible and should be thesame model and sizes and it should be identical to each other.
You should get the correct Specification of your memory. example DDR 400,
You computer battery is only is less than US$ i think its very cheap. but he troubleshoot and he replace the hardrive i don't know if that is the case. PCU or CPU ..when computer still boot there is no problems with this. memory computer will not boot if memory is damage.
Hard drive, Less than 2,500.00 pesos 80 GB
I will suggest you to get all the parts that said damage and bring it your home and consult another computer tech. If you wish to know how to troubleshoot your computer i will teach you.
step by step troubleshooting. melnavz
Posted on Mar 19, 2008
What would cause a Dell Inspiron 580 that powers on but display nothing on the screen?
Some types of memory will only work as matched pairs, try only using two sticks of the same type, Otherwise check your memory and graphics card are seated properly, remove the power cable to the monitor for a few minutes then plug in, check you haven't loosened the monitor cable. Do you get anything onscreen? if you get start up then check BIOS see what memory it reports & the graphics settings. Its most likely something loose or the memory.
Jun 10, 2014 | Dell Inspiron 580 Desktop Computer (Intel...
A few weeks ago my 97 cherokee's check guage came on. Voltage dropped to zero and then eventually drained battery. I removed altenator and had it tested. It tested ok and I reinstalled. When I started it...
Hello, Yes it sounds as if it is a computer problem. There is no way to bypass it you will have to replace the engine computer. Good luck and feel free to ask anymore questions about this and I will do my best to answer them.
Jan 29, 2011 | 1997 Jeep Cherokee Country
Using Windows 7, relatively new HP Pavilion dv7. About a week ago a Memory Dump blue screen started appearing spontaneously, would stay on for only a very few seconds, then restart the computer. There...
hi
memory dump is the result of bad memory module (RAM).. remove the ram modules, look at them, make sure they are same make and part. different manufactures can often cause memory fault in a system
if that's the case, replace the memory modules . you can go to the link below and select the model you have, go to KEYWORD selection, and select MEMORY DIMM, it will then give you the part number you need to replace .
if you need more help, please don't hesitate to issue 4 thumbs and i will give you further details and cost of the modules. you can easily purchase at a link i will issue at that time.
http://h20141.www2.hp.com/Hpparts/Search_Multi_Product.aspx?mscssid=49A90DD091EA4D89B2FC957BD1525074&SearchCriteria=dv7t
please issue 4 thumbs up
Jan 07, 2011 | HP Pavilion dv7t PC Notebook
Just purchased a refurbished IBM ThinkCentre S50 8183 about 5 weeks ago. Installed Microsoft 2010 a few weeks ago. Everything had been working good except for today. When i press the start button .......
so, you eman you power it up , get the OS in working mode and then the START button freezes up ? i dont quite understand.
if you are interetsed, send me your contact information (phone #) and i willc all you
or i strongly suggest you take it back to the seller and get them to figure out why this is occuring
good luck
Oct 15, 2010 | IBM ThinkCentre S50 8183 Intel Refurbished...
No video displayed after updating bios
Yes, it is true and common. Anytime you update bios, also find the method for resetting/undoing the bios update.
go to the mobo mfg website and find how to reset the bios. This usually involves removing the battery, and jumpering the reset.
The reset may not reset/undo the update, but simply reset the bios to defaults.
Depending on the bios type the restore may vary.
Jan 24, 2010 | Computers & Internet
Windows Explorer problem
You might try re-installing IE. Maybe a new installation will debug. It won't do any harm...
Aug 25, 2009 | Computers & Internet
Oil light flashing, last oil change 7 wks ago
I belive they didn't reset the oil light timer. I belive the sequence is 1. key on (not acc with engine off)
2. step on the brake pedal 5 times within 10 seconds. 3. key off. 4. start car. 5. check if the light went out. you may have to try it a few times to get it.
Jun 25, 2009 | 2003 Pontiac Grand Am
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
