Question about Dell Latitude D600 Notebook
Note book dell latitude d600 power failure?
Hi sandrew,
i have one note book found that the mother board inductance blow on incoming power changer. so ,i need to kown that which component going wrong due to inductance blow up .
  • 1 more comment
  • Anonymous Mar 24, 2008
    if a motherboard has no other components addedis there a feedbak loop or should the ligjht come on anyway assumingthe batterry is bot shorted/ or if no battwry is used is there a place to get a schematic diagram of the motherboard or at least the powersupply area and components?
  • bmg21956 May 20, 2008
    Same problem, LT will not power up. When I plus adaptor into pwer, green light comes on the transformer. When I plug the cable into the laptop, the green light goes off and no power to laptop. This happens in the middle of a normal working day - just died. HELP please!!
  • kfsalemi Jan 01, 2009
    I have the same problem - the power indicator of my D600 turns green for about a second or so, but then goes off. I am wondering if replacing the power circuit board will help. I did just buy a new D600 power cord and new D600 battery.
  • 3 Answers
The dell latitude d600 batteries are designed to shut down even when all 6 cells inside are fully charged, based on some tests an internal circuit inside the battery case does. it checks the number of times the battery has been charged, the temperature of the battery and also the temperature of the series of flipflops that count up the charge cycles, it would appear from inspection of the circuit boards inside. the best information ive been able to find since my d600 quit last month, is that this was done after a dell battery overheated and exploded. in understandfable fear, it seems dell was a bit overly cautious in thier protecting consumers from exploding batteries and thus dell from law suits. im glad my battery wont explode, but the rub comes when a perfect fully charged bank of lithium ion cells is isloated from my computer and not allowed to run it by an overly zealous protective circuit, long before any malfunction whatever has occured in the batteries. this is the case we seem to have here atleast in my computer. the cuplrit seem to be that believing i was doing the battery good i charged it each time it began to run low on voltage, and indeed often plugged it in while using the machine if i was near a plugin and often unplugged it in the living room replugging it in in my bedroom when i went to bed or in the bathroom or in the basement, and still wanted to finish looking something up. i believe 500 charge cycles will shut the battery down. i had it for 3 months and unplugged it and plugged it back in up to ten times a day, unknowingly making another click in the battery death counter each time, if i averaged 6 times a day doing this, 500/6 would only take 83 days to reach the dread 500 cycles and abrupt shutdown. a more prudent thing to do after you buy a new battery would be to run it down about 3 hours then recharge once per day so it will run 500 days about 1 2/3 years. how long the battery cells them selves last i am unsure, but a friend who has one manufactured before the recall for exploding batteries, said his has been used for 5 years with no sign of failure. but he risks the possibility of a battery exploding some day. who knows when. i think a more economical approach, while still allowing a safety margin would be monitoring the temperature and the charge capabilities of the battery without regard to number of charge cycles, which would shut it down when there is some sign of a problem that may lead to any danger. but then i dont work for dell. so like you need to do, i just ordered another battery, but i will continue to research how the consarned internal circuit shuts the battery connections off. the problem is complicated by the multipin connector with unreachable female pins inside a connector and no pin out information. but no secret soo simple can stay huidden for ever. the problem is to determine which pins need the 11.1 volt battery output, to run the computer, and which need various other voltages, or resistances, just to tell the computer everything is ok, and providing these pinsw with what they need, so the computer wont reject the good batteries. until its solved though, just buy a battery.
another problem these computers have that shuts them down is poor coverage with silicon heatsink compound on the surfaces of the mocroprocessor and the heatsink, and crappy weak cooling fans. i have completely dissassembled (not recommended for amatures) my dell d600 3 times to replace the dead fan, to clean old dried out heatsink compound and replacement of it with new, and when my good battery refused to run the computer or to recharge and i incorrectly assumed bad connections and dissassembled it yet again looking for the bad connections, only to discover the designed failure of the internal battery circuit. -doug electronics tech for 50 years
Posted on Nov 18, 2008
Pls help.my dell latitude D600 has refused to come up,its battery is fully charged.nd if i plug the charger to main electric power and then plug to my laptop i noticed that the charger goes off.wht could be the problem??.
pls help,its urgent.
larisdena(lagos nigeria)
Posted on May 18, 2008
    New Friend:
    Problem Solver:
  • 10 Answers
Hi Friends,
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
Posted on Jul 23, 2010
    Problem Solver:
  • 14 Answers
  • 44 Answers
As i workewd with dell, The chances are might be of surge protector or leakage in the battery... If u were experiancing excess heat generated , It should be with the batteries....
Kindly give a feed back to Improve my statistics by Rating My advice and to see If it was helpful for you...
Thanks and Regards
Posted on Mar 28, 2008
SOURCE:
D600 wont power up
Try removing the battery and boot on the power cord sometimes the battery shorts the system so it will not boot if it does boot then you need to replace the battery it could be the battery is dead and your power cord is bad check and make sure that is not the case if the power cord is good then I would look into replacing the mother board you can find a replacement on Ebay or at dell .if you have to replace it do a google search on hot to replace the mother board on a Dell latitude D600
and you will ba able to get step by step on how to disassemble it
Aug 28, 2011 | Dell Latitude D600 Notebook
My dell d600 laptop cannot charge it only shows ac power on the screen but not showing charging sign and also it dosent charge the battery also.
its a issue with the mother board,, your not the only one!!!
I have 2 d600 with the same problem!! i tryed a new bat and new cord,, no help,, its the mother board,,, $50-$60 on ebay...IF YOU Find the right tech it should be no more then $160 to fix
Jun 30, 2010 | Dell Latitude D600 Notebook
Latitude D600 PC Notebook: dell d600 three light on and of problam...
This is do to the jack were the power button board plugs into the motherboard, i see this alot on d600 and d610, the lights come on for about 3 sec then computer turns off..
this can be fixed by resoldering the plug to the motherboard but most will say you need a new mother board the leads are small and tight together..
Used motherboard on ebay $60-150
May 17, 2010 | Dell Latitude D600 Notebook
DELL LATITUDE D600 USB PORT NOT WORKING
You can solve this issue by installing usb 2.0 driver in your DELL LATITUDE D600 laptop find Blow Drivers Download Link:
.DELL LATITUDE D600 Drivers Download Link
Feb 05, 2010 | Dell Latitude D600 Notebook
Dell d600 power cord turns off when I plug it into laptop. I tried another power cord and had the same result.
Hi Boss it is the problem of your laptop mother board. replace it it will give you the solution
Dec 10, 2009 | Dell Latitude D600 Notebook
Dell latitude d600, mic works sometimes
The Mic is on the same board that the power button is on.. there is a problem with this board,, the problem is were the power button board plugs into the main board....... when you push down on the power button your affecting the mic''s conection to the main board,, {Its a bad plug}
The Mic is found next to the power button.. to the left look for a small pinhole,, ....try pushing down to the right side of that.. test Mic when you do this,,,
You need a new main [mother] board to fix
Sep 25, 2009 | Dell Latitude D600 Notebook
Dell&tosipa
try looking for CMOS jumper of the mother board to get pass the BIOS password.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 04, 2008 | Dell Computers & Internet
Dell Latitude D600 Notebook Logo
1,434 people viewed this question
Ekse
Clive
Clive
