Question about HP DeskJet 5550 InkJet Printer
HP DESKJET 5550 white ribbon cable.
One of a white riibon cable came out. I need to open the top cover of tthe printer (not the small lid *******). Please help me !
    Problem Solver:
  • 7 Answers
It is easy to reconnect the cable just slot it in
cos
Posted on Jun 21, 2008
Hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
HP deskjet 5550 - Recommended troubleshooting not working
That's an oldie but a goodie. I bought a 5550 in 2002 and it still works!
1. Try disconnecting it from the computer and bring to a clear area with good lighting (kitchen table or garage work bench). See if you can see anything impeding the movement of the cartridges (you are correct...they should come to the center)
2. Power it up againd with nothing connected to it...see if the cartridges move.
I'll check my 5550 tonight when I go home, because I thought the cartridges came out from the Right Side...not the left. I wonder if they are jammed on the wrong side.
I know it's not much help, but I will check some more. Good Luck!
Apr 07, 2009 | HP DeskJet 5550 InkJet Printer
HP Deskjet 932C
With the cover off, there are little white gears down on the right bottom that activate a ink plug tray.
Lid-open sensor is a gray tab on the lid that interrupts a black optic sensor on the circuit board. If your printer gets wet and no power up, unplug printer and short the two capacitors on the smaller circuit board to clear internal printer fault memory. Insulate yourself, small voltage in there even unplugged.
Dec 20, 2008 | HP DeskJet 932c InkJet Printer
Zvonko jelusic from belgrade
The print carriage is stuck.
Solution
  1. Open the top access door on the printer.
  2. Remove the print cartridges.
  3. Close the print cartridge flaps after removing the print cartridges.
  4. Turn the printer off and then on again.
  5. Replace the print cartridges.
  6. Close the top access door.
If the resume light continues to blink after the print cartridges are released,
OR
the print carriage is stuck or makes a grinding noise, follow these steps.
Solution
  1. Lift the top cover to the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
  4. Move the print carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
  5. Take out the print cartridges and close the top cover.
  6. Plug the power cord into the wall outlet. Plug the power cord into the back of the printer.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover
Solution
  1. Open the top cover.
  2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
  3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet
Sep 22, 2008 | HP DeskJet 5550 InkJet Printer
Usb cable missing needing to purchase
There isn't any specail USB cable for it. You can purchase a usb cable from any electronics store.
Apr 06, 2008 | HP DeskJet 5550 InkJet Printer
HOW DO I OPEN THE CRADLE LATCH OF HP 5550?
You've been very careful not to do what you think would break the top cover.  But sometimes you have to take a risk and trust the instructions which tell you to "Open the top cover".  Yes, it's going to require a bit of a jerk to get it open.  If you go to the HP website there's a picture which shows that no release buttons or latches are involved.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09327&lc=en&cc=us&dlc=&product=71896
good luck!
Oct 14, 2007 | HP DeskJet 5550 InkJet Printer
Hp 5550 blinking
remove the 2 ink catridge and cover it back you will see only catridge error light peeping. off it and on it back then put the 2 catridge back i hope this will solve your problem. from .
Aug 10, 2007 | HP DeskJet 5550 InkJet Printer
Well, first things first! Are you using the parallel port (the "wide connector" one) to connect or the USB(The small connector)? Get back to me with this info to continue troubleshooting! regards, babb
May 04, 2007 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
123 people viewed this question
Ben Johnson
