Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Color & sharpness problem
I'm sorry, I don't know my model number but I have a Phillips HDTV 56" rear projection tv. It was bought in 2002 and now the picture is kinda fuzzy and the color seems to have faded. I've tried adjusting everything and I even took the back off and cleaned the bulbs & glass but no luck. Is it worth fixing?
  • arwencarys Mar 19, 2008
    Wow, jut found this place and got an answer in minutes! Thank you troylove11, I had heard of this but wasnt sure if it was for real. I will definitely have a go at this and let you know if it works. Any idea how much it will cost?
  • Anonymous Mar 23, 2008
    how do i get the green color off and make the picture more clear
    Genius:
  • 1,153 Answers
Sounds like you need Coolant fluid change, this is the fluid under the Lenses. If you have not done this before I suggest that you get some one who is qualified. Because if the coolant leaks and get to the circuit board, there goes your tv. You need new fluid in the 3 CRT's. If you look down with the back off and looking in the lense, you would see contamination in the fluid, this needs to be taken out and cleaned and replaced with new fluid. The fluid can come from places like MCM electronics corp.
Posted on Mar 19, 2008
  • Lashawn Robinson Mar 24, 2008
    What do you mean by green color? Do you see lines through picture? Or is set green all over with picture?
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
I have a Phillips rear projection tv model number 60PP9202/17F.....it 60
What is the problem of your
Phillips rear projection tv model number 60PP9202/17F?
Jan 10, 2012 | Philips 60PP9202 60" Rear Projection...
Having i think convegence board problems with my phillips model # 60pp9202/17F called tv repair guy said it was my convergence ..colors are alll orange and bottom of picture kinda bubbles up can i replace...
Replacing the convergence board will require a complete convergence adjustment. A better solution would be the replacing of the defective convergence IC. This would retain the convergence settings for the set. I'll locate the part numbers and costs and update this later.
Dan
Aug 31, 2010 | Philips 60PP9202 60" Rear Projection...
There is no red in picture on model number av56wp74 jvc rear projection tv what's wrong with it?
Ur CRT red gun is dead.Must hire the repairman for this job.It require part is hard to find,and alot of work and electronics skills to do this job.
Mar 17, 2010 | JVC AV-56WP74 56" Rear Projection...
Basic cable connections using rear coxial connection
better call your cable tv provider.it seems that the problem is out of your premises
Jan 13, 2009 | JVC AV-56WP74 56" Rear Projection...
Fuzzy connection on my samsung DLP HLN567W
Try the DVD player on another component connection on the TV. If the picture is still distorted try another DVD player or something with component output. If thre picture is normal with another input device then the issue is the DVD player,
Nov 28, 2008 | Samsung HLN567W 56" Rear Projection HDTV
TV Color
You need to replace both convergence ICs they are both STK392-120 and you will also need four 6.8 ohm 1 watt metal film resistors. You can get the ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Here is the link.
http://servicemanuals.vstore.ca/
Jul 04, 2008 | Philips 60PP9202 60" Rear Projection...
JVC HD TV MODEL HD55G
kinda like a water mark... i fixed a few of these and to me it sounds like something in the optics. eather on the mirror or in the engine... send it to a shop while its still under warrenty. they probally will replace the engine for you under warrenty.
Jan 16, 2008 | JVC HD-56G786 56" Rear Projection HDTV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
179 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
