I would like my computer to shut down automatically after 15 min of not being used How do I set this up
  • 88 Answers
This is power settings, controlled through the display properties applet.
Right click the desktop, select 'properties' (or personalise in Vista) and the applet or menu depending on your os will open.
erch.
Posted on Mar 19, 2008
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
Sharp LC-32LE240M automatically shuts down
It should have come with a one year parts and labor warranty so consider looking into getting it fixed under the warranty--opening set or tampering inside would void the warranty.
Dec 19, 2012 | Televison & Video
Generac gp6500 will not stay running for more than 20 minutes.It shuts itself down then it is hard to restart and when it does start it will not continue to run. If I let it sit for 20 min. or more it will...
Here is support product lookup. Requires more specific numbers about your gp6500.
Shuts down automatically from oil shortage.
Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter.
Jun 07, 2017 | Generac 5623 GP Series GP6500 8,000 Watt...
Notebook keeps shutting down
there are numerous cases why the computer keeps shutting down. One is the pc is slow to react, the other is when the pc is in idle mode, it did not respond accordingly to its idle time to come back to its original settings. These are just the samples.
To solve this problem, kindly turn off the computer and remove the battery and cables to it. Then using your forefinger, press & hold the power button in between 8-12 secs. Then reinsert the cables and battery to it. Turn on the pc and let your computer be idle in 30 mins. If in 30 mins your pc will shut down, that means there is trouble on your memory module inside your laptop. The RAM (Random Access Memory) keeps your computer in safe and running condition for it is avoiding the pc to automatically shutdown. That is the time to consult ASUS about this issue...
Sep 02, 2010 | ASUS Eee PC 1000H Laptop
94 chrysler con.3.3 eng.runs for about 15 min. shuts down,engine
suggest change crank sensor-rear of engine pas side
Oct 05, 2009 | 1994 Chrysler LHS
Pc logs off after 15 mins
Your lap top is either over heating or you have some power/hibernating options set up. If your lap top get really hot, then it's overheating issue and you will need to get it cleaned out.
If it's power options: Click Start > Control Panel > Power Options and set your options to Presentation mode.
Let me know if you have any questions.
Jul 09, 2009 | Dell Latitude D600 Notebook
Dell inspiron 9300 getting hang or restart after every 15 min
Sounds like your hardrive is starting to fail-backup all files!!!
Apr 12, 2009 | Dell Inspiron 9300 PC Notebook
Shutting Down
if it shuts off automatically, not necessary it be a problem with the power. ur computer must have been attacked by a virus. try updating ur anti-virus and removing the virus.
Aug 13, 2008 | OnDemand Telling Stories...
Computer shuts down when VCR is set to
the first things i would try is updating your video card drivers and install the latest version of directx
Mar 24, 2008 | Computers & Internet
RCA 20f510td
Sounds like a thermal breakdown of a componet. it could be in the main power supply regulaor supply or even a bad capacitor in the power or sweep supply. In some cases Zener diodes can break down and change values after warm up. In some cases also bad solder connections in the highvoltage section, or the power supply can cause this problem. It is a hard call without being able to look at the set. Just a few leads on where to go first. most likly a combo unit, such as this one , would cost you more then a new one these days. Good Luck PS Please dont forget to rate this thread.
Dec 09, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
