Question about Refrigerators
Cuisinart Private Reserve cwc-900 wine cellar stopped cooling
I have a Cuisinart Private Reserve cwc-900 wine cellar, which has stopped cooling. It has a Thermoelectic compressor-less cooling system, which looks like a little square plate sandwiched between to heat sinks, one small and one large on the exterior. It looks like some fluid has drained from this apparatus but I don?t know from witch part. I have disassembled it and the square plate (part # tec1-127-08) was covered with white stuff that resembles wet paint. The plate still gets hot. Does anybody know what I need to do to fix this and would it be worth my time?
Thanx
Bryan
  • 4 more comments
  • fritter1194 Mar 19, 2008
    Thanks, There is hardly any compound left and the works but seems slow, I'll change the fan and put more compound on the square plate.
  • Anonymous Nov 25, 2008
    Hello Fritter.
    How did you get the unit apart?
    Thanks.
    Chris
  • steve Dec 05, 2008
    My unit is not cooling either and I hear a fan runnig but I can't get it apart to see if the heat sink plate is getting hot. Whatdo I need to do to check it.
    Steve
  • pbamma Jan 09, 2009
    I too have this wine cellar. Wish I would have kept the documentation/warranty. I've had it for 1 year and 5 months. Hopefully my computer building skills are good enough to fix this.
  • JC2009 Feb 28, 2009
    Dear Fritter, I had exactly the same problem you had! Did you solve yours?
    BR,
    JC
  • Motorola Mobility
    Motorola Mobility Mar 17, 2009
    Mine stopped cooling as well. The serial number label is horrible. They put it on there with several wrinkles. Fortunately I was still able to read it. I received it as a wedding gift almost two years ago. Now the thing is a hunk of junk.
I also had one of these CWC 900 units that quit working. The interior temp was 77deg F and the outside was 70 deg F.
The exterior panel was very warm to the touch where the heat exchanger was.
Like a previous person stated, there are two fans. One on the control unit board and then the main cooling fan for the exchanger. In my case, this main cooling fan had quit working - allowing excess heat to build up.
Solution: Unplug the unit! Remove the side panel of the CWC 900. First remove the 8 "finishing" plastic plugs that hide the screws. This was done with a sharp point on an ice pick to pry them out. Then remove the 8 screws with a torx T10 driver. At this point, plug the unit in and lower the temperature setting. In my case the small fan kicked on and the larger one did not. Un plug the unit. If you try and manually turn the fa you will feel resistance. Remove the cooling fan and black housing w/ 4 phillips screws. seperate the wires from the cable ties and then unplug the fan - you may have to remove a small amount of a plastic type glue to unplug the fan. Remove the fan from the plastic housing w/ 2 phillips screws. This is a fan made in China and I was unable to find a replacement on the web. Remove the center sticker on the back with the fan model number. Remove the center black plastic plug with a sharp point. You will now see the end of the shaft and a small split keeper ring. This ring is made of plastic - be gentle. Pry it open and remove it from the shaft (KEEP IT). Once the keeper is removed, you will be able to pull and seperate the motor from the fan blade and expose the shaft. I was not able to remove the small bearing from the motor so I wipe the shaft clean, applied white lithium grease and the re-assembled the unit. Fan spun freely. Put everything back together and the unit should be fixed!
Hoped this helped.
Posted on Feb 14, 2009
  • SuthernGurl May 24, 2012
    Thanks cajun! We picked up a cwc 1600 for $20 at a resale shop. We got it home and discovered although it "ran" it wasn't cooling.. we followed these instructions and now its working great... we didn't have grease though, so we used a
Finally, after about 5 months of a non-working unit, I believe I have got this cwc-600 up and running again. Many of the cwc-900 owners spoke of 2 fans but this unit has 3. I believe that translates to 2 cooling fans (located in the back of the unit) and 1 blower fan (located inside). My problem was with the fan inside which was not functioning at all and resulted in a higher inside temperature than that in the room.
To fix this I used the following:
1) Phillips screwdriver
2) Vegetable Oil (didn't have anything else on hand)
Working from inside the unit, I unscrewed 4 smaller screws from the inside-back. This released the fan shield in which the fan was attached to the center with 4 larger screws. I sprayed compressed air on the fan and spun it around a bit. After plugging it in I noticed that the fan began to spin again. After unplugging it again, I doused the fan with vegetable oil in hopes that it would reach the inner axel. After reassembling, it seems to be spinning freely, and hopefully I can enjoy properly cooled red wine again.
Posted on Jun 24, 2009
  • pbamma Oct 21, 2013
    Update to my last post. The vegetable oil fix didn't last long (something like a month). I've since ditched the unit.
I had a similar issue with mine, and pulled it apart (drilled out the plugs, and used a torx screwdriver). There are two fans. One cools the control unit, and one is a blower on the heat exchanger cooler. The blower fan had seized up (it had some dust binding up the bearing). Unfortunately, I busted the motor trying to clean it. Putting a house fan on the heat sink while the unit was apart demonstrated that it still worked fine. I am going to try installing a cheap computer heat sink fan to see if I can fix it with a $20 fan from Radio Shack.
Posted on Dec 31, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 32 Answers
I haven't seen the unit you refer too but it sounds like many others that I have seen. The white stuff is heat transfer compound as used on CPU heat sinks, DO NOT WIPE IT CLEAN, if you have then it will need replacing. Check the fan is running at full speed to cool the heat sink that the plate is attached to. If there is no fan then there isnt much else that can be wrong with it apart from the control circuit, but that seems to be working as you say the plate gets hot.
Posted on Mar 19, 2008
Why doesn't it cool?
If I unplug the Peltier the unit starts right up, the display working again and fans come on . Is Peltier shot ?
I also can't find the 4.5inch fans for unit Fan Model # SD1225S12L. What would happen if I leave Peltier unplugged ??
Dec 17, 2015 | Cuisinart CWC-1600 Private Reserve Wine...
Cuisinart wine cooler not cooling
Hola, buenos dias. Tengo 2 cuisinart cwc600 y no enfrian. Me dijeron que era la tarjeta electonica. Donde puedo comprarlas? Gracias
Oct 06, 2014 | Cuisinart Private Reserve CWC-600 Wine...
Light bulb burned out...........can't find one.cuisinet wine cooler
im a union electrician i would contact a company like graybar electrical supply or granger.com
Sep 12, 2012 | Cuisinart Private Reserve CWC-900 Wine...
Can not get wine cooler to get cool. Red lights keep,blinking. Need structions on how to set it.
If the light is on and no fan or compressor is running then its your thermostat that is bad. That's the only thing that turns on those parts. As you said the unit is new you should contact your dealer either to replace it.
Keep us updated.
Aug 20, 2011 | Cuisinart Private Reserve CWC-900 Wine...
How do i get the cabinet off to get to the fans on a cwc 900
You'll have to drill out the little plastic tabs which hide the star screws. I used a Dremel and a quick tap on each little tab to make a small hole, then pried out the plug. Then use a star tool (T10) to remove screws. The fans get dusty and sieze up. Lousy assembly to keep clean, but will be easier now. I had to replace the larger fan.
Nov 24, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Cuisinart wine cellar CWC-900 "Both fans are dead"
CONTACT COMPANY : DENVER BETA 303-431-7161 MODEL # YW06010012SL ONE MONTH LEAD TIME... THIS IS A SLEEVE BEARING MODEL THEY HAVE A BALL BEARING MODEL THAT SHOULD WORK ITS GIVEN MODEL IS YW06010012BL REPLACES DFC601012L
Sep 04, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Unit will not cool. Stays at room temp.
based on my personal experience it may be a bad fan. can you feel the fan running? or does it just feel hot near the vents?
Jul 31, 2009 | Cuisinart Private Reserve CWC-900 Wine...
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Jul 22, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Refrigerators Logo
7,748 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
