Question about Dryers
Kenmore dryer won't start
My dryer doesn't start.It's a Kenmore model #110.96429100. I just replaced the motor in January of this year. About a month later it started blowing the thermal fuse. I have replaced it 3 times. I just replaced it and the cutoff thermostat and the 250 degree thermostat on Saturday. After 4 loads the thermal fuse blew again. The only other thermostat is the 150 degree thermostat which is just below the thermal fuse. I checked it with an ohm meter and it has continuity. Any ideas or suggestions is greatly appreciated.
    President:
  • Dryers Master
  • 2,651 Answers
Your blowing that many thermal fuses, id replace all the thermostats. (2) come in one kit both on heater box 1 top and one bottom. id also look into your venting, a clogged fo kinked vent is going to overheat the unit and blow all sorts of stuff(not to mantion the potential fire hazard of a bad vent
Posted on Mar 19, 2008
Can anyone tell me why my dryer just flashes and I can not turn it off or on?
Electronic components rely heavily on having a good ground connection. Without a good ground, Mr.Gremlin can make an appearance, anytime, anywhere.https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link may be of some help in a diagnosis.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 23, 2017 | Kenmore Dryers
Motor hums doesn't start
What is the model number of your unit?
Oct 31, 2012 | Kenmore Dryers
Kenmore dryer 592-89047 won't start
Sounds like the lint may have fallen into the fan and has jammed it. The motor will hum if that happens. Its an easy job to clean just take your time taking the blower cover off and reverse the process replacing it.
Apr 26, 2012 | Kenmore Dryers
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
Gas dryer will heat sometimes and not heat other times kenmore model 72802
sounds like bad gas coils,you have to send the whole model number,it will start with 110. or similar,if the bottom panel comes off,remove it,start the dryer, or in the front panel down near the bottom pop off the cover and look in,if the flame lights and then after 10 to 20 minutes the flame doesn't light you have bad gas coils.when the coils are starting to fail they will work correctly until they heat up and then they won't work until they cool down,the coils are what opens the gas valve.the coils are on top of the gas valve,remove the two phillips screws,pull off the cover,remove the wires from the coils and install the new coils,put it back together and you'll be fine,also while you're in there,get a shop vac and vac out the cabinet,stick it on blow and blow all the lint off of the motor and out of the gas tube,then clean out the duct that the lint filter slides into.if your vent line is a long run from the back of the dryer to the outside,i use a leaf blower remove the vent line from the back of the dryer and blow all the lint outside out of the line,do this once a year,you won't have any fires,your clothes will dry on time and your motor and parts will last longer
Oct 28, 2011 | Kenmore 72802 Gas Dryer
No the dryer won't start it make a hum sound but the barrel doesn't turn(I check ed the belt it is fine) maybe the starter switch you think. Chris
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2011 | Kenmore 62602 Electric Dryer
Kenmore model 66812694 - quits running, buzzing noise at restart
bad motor,when you hear that noise open the door,hold in the door switch with one hand and with the other spin the drum and have someone else start it while you do this,all your doing is helping the motor start to spin but it sounds like a bad motor,this could be from not cleaning out the dryer,if it's gas it should be done once a year,electric can go another 6 months because there isn't an open flame in there,if you clean out the dryer and vent line the clothes will dry on time,the parts will last longer and you won't have a dryer fire.
Nov 19, 2017 | Kenmore Dryers
Model 11060052991 kenmore elite dryer
For heat issue I had replaced the heat relay switch a year ago and that worked. For the start button holding issue I replaced the motor relay switch and the dryer is fine again.
Nov 25, 2007 | Kenmore 63942 Dryer
Dryers Logo
178 people viewed this question
Top Dryers Experts
