Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby button blinks no picture no sound tried to reset and restart tv does not turn on
  • 1 more comment
  • Anonymous Mar 20, 2008
    13 blinks then 2quick on and on and on
  • jbjunk1 May 09, 2008
    I have the KV-36FS120 and this started a few days ago after an electrical storm. It came back a few times after hitting the poswer button a few times repeatedly. It will not come on anymore and it flashes 9 times. I called the local repair shop and they said this meant it was either a power supply failure or some internal signal failure.
  • letgod May 10, 2008
    I have a 36" Sony Trinitron Wega with the same problem but I have never counted the blinks. It blinks all the time when I turn it on. Someone suggested to me that it was a problem with the mother board and was not worth fixing it. Is this true?? I really don't want to buy a new TV, however it sounds like I might have to. [email protected]
  • 4,234 Answers
The set should show a repeating blink "count". Please post that count here. When the set enters protective shutdown, the circuit where the problem occurs is indicated by the blink count. With that info, I can point you to the faulty circuit as well as the most likely defective parts.
Dan
Posted on Mar 19, 2008
SOURCE:
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
No Picture on Toshiba 42RV530U
I had a similar problem to this yesterday. Tv is same Toshiba model as you mentioned about 4 months old. In my case, after the TV working perfectly following installation, the standby LED on the front (the one that is red on standby and green when on) went to a flashing orange (after switching on from standby) and the picture disappeared although the sound remained OK. I was unable to get any response from the setup or menu on the remote, otherwise I would have tried resetting the TV. Regardless of how much switching off/on (including disconnecting the powerlead and leaving for few minutes), disconnecting all peripherals, etc., nothing helped. I looked up Toshiba's web site and under support they basically suggest switching off the TV and restarting using the onset buttons (not the remote) and pressing the menu button (again the one on the set (not the remote) and if you could get the menu box to appear then reset to default settings. I tried this but the results were the same. I therefore thought the TV was defective. However, after much frustration I did the following (I think): 1) Disconnect everything from the TV 2) Powered up from the mains switch whilst keeping BOTH the startup and menu buttons on the side of the TV pressed down. The result in my case was that the standby led and one of the two beside it flashed green simultaneously. However, when the buttons were released, the TV started up the same (flashing LED orange and sound no picture). 3) Pretty well defeated at this point, after doing the procedure at (2) several times with the same results, I somehow thought of pressing the standby button on the remote either whilst the two buttons on the set were depressed or just after they were released. I am afraid I cannot remember which and cannot replicate the problem as I don't know what caused it in the first place. 4) The TV then started normally ( no reception as I had not aerial connected, etc.,) but I was able to gain access to the screen menu/setup buttons via the remote which were in French rather than English. However, after reconnecting everyrthing the TV has worked fine (obviously after resetting the language via the menu). I am sorry I cannot be more precise but I hope this might be of help to someone with a similar problem.
Oct 04, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Standby red lamp on my KP-51W5510 blinks in an 8 blink pattern
Try this first HOLD DOWN THE RESET on the remote while pressing the power button on the TV.
If this does not restart it one of the IC chips has failed and it will require repair
please rate this help top keep our service online
Aug 17, 2009 | Sony Grand WEGA KDP-51WS655 51" Rear...
Standby light continuously flashes with no picture or sound
count the number of blinks; you may have to unplug the set and try to turn on again--if it does not blink in a sequence(3 blinks, a pause etc) the set is in shutdown and many things can cause this.
Aug 06, 2009 | Sony KP-53HS10 TV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Standby/power button blinks with no picture or sound
id take it and have it repaired. people on here can tell you what they think it is but no one knows for sure what is causing the problem. a repair shop can guarantee the repair.
Jan 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
No picture, no sound, stand by timer light flashing
Need a little information here...
1. The TV remains on, yet there is no picture and no sound? Or does the TV turn off altogether?
2. How many blinks does the standby light give? Are they continuous? Is it the same each time, or random?
3. Did anything else happen before this, or did it just happen one day?
Answer that and I'll try to help with what I know.
Jun 09, 2008 | Sony KV-32V40 32" TV
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
standby button blinks no picture no sound have tried to reset and restart nothing has worked to get tv to back on
Mar 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking STANDBY Light front of Television
Hii...
Refere to Sony Blinking Codes :
5 Blinks ===> cause AKB circuit (AKB). Something is wrong with the video. check components on the C board, also check the A board. Also unit be in IK blanking, try turning up screen slightly.
Hope can solved the problem....
[Vrya]
e-mail : [email protected]
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture no sound
Last night i set childlock in my nikai ( NTV34010) tv set and tuned off by remote control.Then after some time later i tried to turn on tv but there is no sound and no picture.
will u please help me to solve it out.
Dec 02, 2007 | Panasonic CT-36D32 36" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
112 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
