Deskjet printer MyJet model MJC-655V
I can't find an ink cartridge for the above printer, also I have no software and driver for it. The printer i think came from korea.
  • kaloy Mar 19, 2008
    My printer can take M10, M20, C10 AND P10
    Genius:
  • 1,027 Answers
The M50 ink cartridge is the Lexmark 12A1970 or lexmark #70
the printer is a Samsung The Windows XP has a generic Samsung Driver for the MJC650 series which should work
JGS-50B M50(12A1970) MJC-805G/GC, MJC-850S/SC, MJC-860X/XC, MJC-900G/GC, MJC-902G, MJC-960iu, MJC-965cu, MJC-965ce, MJC-965cy, MJC-965C, MJC-97
Posted on Mar 19, 2008
  • 2 more comments
  • Mark Williams
    Mark Williams Mar 19, 2008
    Does your printer take the M50 or M10/C10?
  • Mark Williams
    Samsung Ink M10 Black Ink Cartridge (Interchangeable with Lexmark 15M0640
    Still looking for which lexmark is interchangeable with C10/P10
    Color 10/ Photo 10
  • Mark Williams
    Lexmark Color Jet printer 1000/1020/2030/2050/2055/3000
    use the same cartridges.
    13400HC black
    13619HC Color
  • Mark Williams
    Samsung
    Order No.
    Genuine No.
    Printer models
    JGS-KM10B
    M10(1380620)
    Samsung MJ(C)630/640/650 Office Master CF4000/4200
    Sindoricoh COLOR CAP300/330 Lexmark Color Jet printer
    1000/1020/2030/2050/2055/3000 WinWriter 100/150C Medley
    ExecjetsⅡ,IBM-4076
    JGS-KCI0C
    C10(1380619)
    ExecjetsⅡ,IBM-4076
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
I have put a tesco hp compatible ink cartridge in my hp 2050 deskjet printer but a msg comes up INCOMPATIBLE INK CARTRIDGES The cartridges listed above are not intended for use in this printer as...
This model Cprinter may only let you use genuine printer cartridges. If you try to refill these ink cartridges it will not work because the cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
Mar 26, 2013 | HP Deskjet 2050 All-in-One Printer
How do I put in a new ink cartridge?
For what model and brand of printer?
Most ink cartridges can be replaced by following these instructions: http://www.wikihow.com/Replace-an-Empty-Ink-Cartridge
For further information, follow your owner's manual. You may also be provided with instructions from your printer portal on your computer.
Jun 21, 2012 | HP Deskjet F300 series
Sir I have HP Deskjet -D1460 and my black cartridge not printing
In most cases the printer driver software can have errors while being in use or is shut down. First remove the ink cartridges, the B&W . Now to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Sep 17, 2011 | HP DeskJet D1460 InkJet Printer
How to make the HP Deskjet 3054 Print in only black
Select 'Print' from your software package and then 'Preferences'. Select the 'Color' tab, click on the 'Print in Greyscale' box and select the 'Black Cartridge' box..
Jul 13, 2011 | HP Officejet 5610 All-In-One InkJet...
I have an hp deskjet 940c. I don't know if this is the same model as deskjet inkjet. Anyway what light is on or off on the front when a new ink cartridge(s) is needed?
For the HP 940c, there is only one light to indicate a possible low ink cartridge. The LED above the cartridge symbol (the only one without a button) will flash. (Note: this LED is the second from the left.) When you see the error code, open the printer's top cover. If the error is a low ink issue, the LED will stop blinking.
With the cover open, the cartridge carrier will move until the yellow arrow lines up with an icon on the printer itself. These five icons are in order from left to right (as you look at the cartridges) : tri-color ink cartridge problem, black ink cartridge problem, tri-color ink low, black ink low and cartridges OK. If both cartridges are low, replace the one indicated by the arrow. Then the cartridge carrier will move to indicate the other cartridge is low. (If only one has a problem, after you replace it, the carrier will move to the cartridge OK symbol.)
If HP offers the full-feature software for your OS, then install the software. Use the HP Deskjet Toolbox to get exactly which cartridge needs to be replaced without needing to be ready to replace both (or to monitor your ink level (approximate ink level)).
The manual for the Deskjet 940c is available as a PDF from HP: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=125&prodTypeId=18972&prodSeriesId=35985 .
I hope this helps.
Apr 11, 2011 | HP DeskJet 940c InkJet Printer
My HP deskjet d1460 is showing offline after cleaning the print cartridges. How do i rectify the problem?
Possible that the drivers were corrrupted , hence to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Mar 21, 2011 | HP DeskJet D1460 InkJet Printer
337 people viewed this question
jasbo
jasbo
