Uninstall the printer and all the drivers with it. dll error is a communication(driver) error meaning it's corrupt. Download the newest driver from Epson's website for your OS
Hello
You can get pictorial view to change ink cartridge from the Epson Web site by clicking HERE you just need to click on "Remove and Install Cartridge"
Hope This helps, if so do rate the solution
just press the ink button (with the drop symbol) once and the carriage will move to change ink position, you can now change the cartridge. when your done, just press the ink button once again.
Be sure you have a new ink cartridge before you begin. Once you start
the ink cartridge replacement procedure, you must complete all the
steps in one session.
Make sure the EPSON Stylus CX5400 is turned on and not printing. The LCD screen tells you which ink cartridge is low or empty.
If your EPSON Stylus CX5400 is low on ink, press the left Menu button until you see Change Cartridge, then press the Color Copy button.
If your EPSON Stylus CX5400 is out of ink, press the Color Copy button.
The ink cartridges move to the replacement position.
Lift up the scanner.
Pinch the tabs on the front and back of the cartridge, lift it out of the printer, and dispose of it carefully.
Before you remove the new cartridge from its package, shake it four or five times.
Unwrap the new ink cartridge and lower it into its holder, then press down on the top of the cartridge until it clicks in place.
Caution: Don't touch the green circuit board on the back of the cartridge; you may inhibit normal operation and printing.
If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7.
Carefully lower
the scanner and press it down until it clicks into place. The EPSON
Stylus CX5400 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on.
Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX hasn't moved or made noise for more than 5 minutes.
