Question about Tivo DirectTV Remote Remote Control
I can't program my universal remote to my tv
I bought an Akai LCT2721AD flat panel tv today and can't seem to get my universal remote to work with it. can you help
I found these codes for this Akai (in which I'm totally dissapointed) and successfully programmed my DirectTV remote using 11675. Good Luck,
Posted on Jul 29, 2008
SOURCE:
What is remote no akai Black Belt ct 2018
You can use a universal remote control with this TV. It can be bought from most of the electronic spare part shops. It is pre-programmed, and no programming is needed.
http://electrohelponline.blogspot.com/
Aug 18, 2015 | Akai Televison & Video
AKAI 27"LCD SN:60683669 Have HDMI connect o
Universal remote controls (like the one for your comcast cable box in which it allows you to control other devices) have "the most popular" IR codes programmed inside of it. When you type in the numbers "10812,10702, etc" you are telling the remote to use that particular IR code within its "database"
The key thing to know is that universal remotes do not have every code, just the most popular. If you have tried all of the codes listed in the manual for you model TV there's not much you can do.
  • Try searching for a code. Some brand names, such as "Akai" may have other manufacturers parts inside of it, Searching usually is done by going through certain key-presses on the remote to try all of the codes available.
  • Buy another Universal remote, not all remotes are created equal as some have mode IR codes built in than others, if you have an odd brand TV, it may be more difficult to come across one that works.
  • Buy a learning universal remote, although usually more expensive these remotes will allow you to "learn" the IR codes from your old remote to the universal remote.
I hope this helps.
Mar 06, 2011 | Akai LCT2721AD 27 in. LCD Television
Akai TV remote is not working correctly
I don't think the Akai remote is designed to work with cable or satellite service. I have to use both remotes & I have Direct TV.
Try unplugging the TV for a few minutes then plug it in and try the remote again. I had the same problem shortly before my Akai LCT2721AD quit working altogether. Three 1000uF capacitors blew in the power supply. Bought 3 new ones and replaced the blown ones myself rather than pay over $100 for a new power supply. Works fine now.
Oct 23, 2009 | Akai LCT2721AD 27 in. LCD Television
REMOTE CONTROL DOES NOT WORK...
if all you need are basic functions any universal remote will work. wall mart will have cheap ones
Jul 07, 2009 | Akai LCT2721AD 27 in. LCD Television
Akai Reomte has stopped working, Universal Remotes will not
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Jun 25, 2009 | Akai LCT3201TD 32 in. LCD Television
Early 2000's AKAI ATV 140 (Tv / Video Combo)
Mar 31, 2009 | Akai LCT2701AD Television
Need a unviersal code for 27 akai tv
Dec 12, 2008 | Akai LCT2715 27 in. LCD Television
Dishnetwork Remote
the way i program a remote is hold the tv botton on top for five sec. till all lite up on top, then press tv power botton (little red)then slowly channel up till tv turns off, then press pound to set. some combo tvs wont take
Jun 11, 2008 | Akai LCT2716 27 in. LCD Television
Tv got a mind of it own
To unlock the V-chip on any tv you must contact the Manufacture of the tv by their 1800 number and if this tv has a built in Dvd player, universal remotes will not code to the tv due to it being a 2 in 1 model. Most Direct tv services also cant program their remotes to these tvs due to the same nature.
Give Akai a call on their 1800- and see if they can go over their process of how to remove the v-chip lock. And get a estimate on a replacement remote.
Jun 05, 2008 | Akai LCT2721AD 27 in. LCD Television
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Tivo DirectTV Remote Remote Control Logo
279 people viewed this question
Top Tivo Televison & Video Experts
Damen Wong
Damen Wong
ray gallant
ray gallant
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
