Status on my computor says disabled all lights are on router may computor is millieum 98 could this be the problem
    Sergeant:
  • 349 Answers
Go into the device manager and make sure it is enabled,if not ,enable it and all will be well.
good luck
Terry
Posted on Mar 19, 2008
Should the status light be blinking?
you should call the wireless manager.
good luck.
Jul 26, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
My wylan light dont light up
does the router work? put tape over all the lights so you arent annoyed by one light out on an older router.
check to insure a solid connection for all cables on the back of the router and each device connected to the router.
Jun 10, 2010 | Linksys Wireless-G WRT54G Router
Status light isn't lit
If status light won't lit, there might be inside hardware problem in the router or maybe just the led is broken. Does your router still works just the status light wont lit or status light won't work plus the router? If the 2nd case is true then the router may be broken.
Jan 03, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
The only light on my router is the router light. No other lights are coming on. I have tried rebooting.
When facing the router, Globe/Internet LED is on the right. Below are the LED indicators; Check the steps below:
Wireless Security - This light will only turn on if the wireless security is enabled.
Wireless-Computer Status - This light will turn on if a wireless computer is connected to the router.
Wired-computer Status - This light will turn on if a wired computer is connected to the router. Connect the wired computer to any gray port on the router. (There are 4 gray ports).
Router Status - Power light. Solid blue means the router is on and ready.
Modem Status - If this is off, it means the router is not connected to the modem. Make sure the cable is connected from the modem to the yellow port on the router.
Internet Status - This light will indicate if the router is connected to the internet.
If this is the first time you are installing the router, then what is important is to get the router, wired-computer and modem lights ON. Once they are on, you may insert the CD that came with the Belkin router to setup the internet connection and wireless settings.
Dec 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Laptop not connectiong to wireless network
Connect the Laptop to the router with ethernet cable
Verify the wireless LAN
  • Open a browser and type http://gateway.2wire.net; the Home page opens.
  • Click the Home Network tab.
  • Verify the wireless status located on the right panel (Status at a Glance) is Disabled.
  • When the status is disabled, then enable the wireless LAN .
May 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Bitcomet and Belkin router
To fix this issue all you have to do is,You should open the bitcomet downloader portnumbers on the belkin router,you need to open default page by typing 192.168.2.1 in address bar.
And also i would like suggest you to disable firewall on router and check for firmware update... It may be quiet difficult for you to do all this.please call tollfree number"belkin" and ask them to change these settings which i have mentioned.and it will definitely work.....
.....Hope this is help full for you
Apr 14, 2009 | Belkin (F5D7230-4) Router (587009)
Cannot access Belkin security settings
avast virus disable it then try it you get the other wise reset the router and re-configure it after reset you get the all configuration in default setting then you easly get it but anti virus disable then work after then you can enable
Feb 26, 2009 | Computers & Internet
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Wireless router problem
Look I have found virtually 98% of the time these problems disappear after a "New" unit is substituted... so my punt is for ya Router...
Sep 10, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
