Question about Linksys Wireless-G Broadband Router
Linksys wireless problem
We have linksys wireless internet for a few years now, and use a wireless-g 24 GHz, 54 Mbps, Broadband Router.  Recently we have been having lots of problems getting the internet to work.  It has worked fine in the past.  The wireless doesn't work on both computers we have in the house.  On my computer it says that "you have successfully connected to the access point but the internet could not be found" or something like that, even when the wireless isn't actually connected to the modem (we started hooking up the other computer directly to the modem so at least some of us can get online) It works fine when the computer is hooked up directly to the modem. on the other computer when the wireless is hooked up it says that the wireless is working fine, but the internet never shows up.  I've tried unplugging it and the modem and waiting 30 seconds, but nothing changes when I turn them back on.  we disabled our security codes so that can't be the problem either.
  • Anonymous Mar 24, 2008
    i have the same problem what is the solution
We are having the same problem. When we unplug the router and just plug directly into the modem the internet works again. It's sad because a friend just got the wireless part of the router working again (before we were having to plug into it with ethernet cables) and now the router isn't working either with a direct or wireless connection. I'm hoping there is some way to fix this apart from buying a new router (which I don't think my housemate will spring for).
Posted on Mar 24, 2008
    Scholar:
  • 74 Answers
Hiya krazy327... sorry to hear about your prob.. we,ve all been here at some point!
Can you let me know if it is one specific computer that the problem is with?
If so .. how are you wired to the router "True" wireless or usb/ethernet gateway from the router?
Regards Faggly
Posted on Mar 19, 2008
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
May i have a quuestion to you regarding my problem on how to set up the linksys broadband router 2.4 ghz 54 mbps through my loptop? pls answer me asas pls.!!!!
you need to configure your linksys router. to do this
connect to the router with a cat5 cable in any of the lan ports.
open internet explorer and go to the http://192.168.1.1
the default login/pass login : blank pass: admin
if you had changed this before please use that login/pass. or reset the router if you can't login by holding the reset button for 30 secs.
once you login go to the wireless button.
there you can set the SSID of your wireless network. this will be the name of your wireless network.
then go to wireless security to set the security to WPA.
choose a good passphase that you can remember.
apply the settings you had made.
on your laptop unplug from the router and search for a wireless network. you should see the ssid name that you made.
connect to it and it will prompt you to input a wireless password.
put the passphase that you setup for your wifi.
you should now be able to surf the internet wirelessly.
Mar 28, 2011 | Linksys Wireless-G Broadband Router
My router stopped communicating with modem
LinkSys Wireless-G WRT54G 2.4 GHz Broadband Router with 4-Port Switch:
Go to LinkSys Login. wrt54g_back-panel_mini.gif Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
There are two ways to reset the Router's factory defaults:
The Internet port is where you will connect your broadband Internet connection.
Please Rate Me
Nov 17, 2010 | Linksys WirelessG Broadband Router with...
Can only get a 10 meg when connected via cable to srx 200
The speed of your wireless adapter maybe up to 54 Mpbs only, check the wireless adapter that you have if it is 802.11 G its set to 54 Mbps only however if your using 802.11 N the speed of the adapter is around 300 mbps of connection.
There's a settings on the router that you can lock WAN port speed to around 10/100/1000
Note: To have a 300 Mbps of connection you should set the wireless settings of the router to WPA2 and AES with bandwidth of auto 20/40
Mar 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys wireless-G 2.4 GHz broadband Router
Since you have problem with your router and geek squad is asking you to pay a big amount of monye just to make the router work, I suggest you contact Linksys tech support so they can help you with your concern and they are free and open 24/7, this is there number its 800-3267114.....
Nov 30, 2008 | Linksys Wireless-G Broadband Router
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Wireless G broadband router
Please go to www.linksys.com/download and download firmware version of your router. For manual upgrade call linksys at 18003267114 or check out other linksys numbers.
Oct 15, 2007 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
228 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
