Thank soooo much Benham!!!!!!! I would give u a hug if you were here in my house. I thought the oven was broken. I only had it for couple of months and it is brand new. I held the broiler button down and it is on (f). My oven is normal again. Thank you very much.
Thank you @benham! That worked for me tooo! Holding down the broil button until the C popped up then used my arrows to convert it back to F.
SOURCE: Ovens won't heat up beyond 250 degrees.
if you cant program it for more than the 270 you may have changed it from farienhiet ( bad spelling) to celcius. pushing and holding broil may switch it back.
SOURCE: NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
SOURCE: Oven heating problems
I'm afraid you might need a new thermostat. The only other thing you might check is to make sure that your 'vent' is not blocked with a pan or tea kettle etc., but I'm pretty sure it is a thermostat.
SOURCE: Oven does not maintain temperature while cooking.
Is this a gas unit? If so you might have a weak oven igniter.
SOURCE: Whirlpool Electric Wall Oven RBS275PDQ6
sounds like board to me, it could alsovbe a problem with the interface like a bad key. self clean runs very high temp and the whirlpool and kitchenaid built ins have been bad about self clean cooking the electronics. the board is expensive but easy easy to replace
benham thank you so much! We had a power surge yesterday and apparently the oven decided it wanted to be C instead of F... appreciate they help!
