Question about Goodmans GPDR40 Digital Media Player
Freeze When i turn on my goodmans GPDR 40 media player it turns on the screen to the initialise message for about 30 seconds or so then turns itself off. Can you help me resolve this? The PC does not "find" it because the unit does not boot up properly. Any idea's would be gratefully received. Regards Jon H email: [email protected]
Check if the connection to the hard drive has come off. If you are a bit technical, unplug it from the mains (otherwis it will be live, remember), take the back off, push the connection into the hard drive, just in case it is loose. If the problem still exists, then you will need to take the hard drive out, and check the connection on the other end of the thin cable. That should do the trick
Posted on Mar 21, 2008
6ya staff
SOURCE:
Drivers
Heres the link to the download page for the software.
http://playerzipfile.googlepages.com/
Hope this helps, feel free to leave a Fixya rating, Thanks for stopping by.
Jan 06, 2009 | Goodmans GPDR40 Digital Media Player
Zoom problem
The maker says it will go off by itself after 30 seconds.....If this is not the case see if there is a display button and turn display off,
I hope this is of help!
Jan 03, 2009 | Goodmans GCE5000 Portable DVD Player with...
Goodmans GPDR40 problem
I had the same problem like everybody else since 2005 . GOODMANS GPDR40 X-Pro personal Media Centre. After Initialise the screen freezes - MASS STORAGE
DIRECT PRINT.
I have suspected that was the battery at fault or something to do with the power.
Why?.Because i have managed to let the Goodmans work, but only for a long time when
connected to the main adaptor.
I use it to record Video from sky,Or to use the unit as a storage drive.
Here are the steps to regain possession of the Unit.
First discharge the unit by leaving the screen on when in direct print mode,
(Move the cursor down to access this mode, normally it does this automatically.)
Make sure the screen display stays on in order to help the discharging of the battery.
Having the screen on will not switch the unit off until the battery is flat.
To have the screen on press the top button again if the display revert to a blank screen.
Once the unit is discarged the the unit will turn itself off.
Now we can connect the power lead to the unit and start the unit once more.
It normally last a couple of hours or more,but it will stop again eventually.
My suspicion is that the battery charger control is not working right and
after a period of time, may be a year ore less, will cause this problem
to all these units.
I hope it works for you too, even if not as before.
Ciao a tutti!
You can contact me at this email address:
[email protected]
Apr 10, 2008 | Goodmans GPDR40 Digital Media Player
MP3 player
Does any messages turn on on the screen
Mar 23, 2008 | Sony Network Walkman NW-HD3 MP3 Player
Black screen
Sometimes the player crashes with a blank black screen. It looks like it's turned off, but it's actually hung. Try holding down the power button for about 30 seconds, or until the player reboots itself.
Nov 09, 2007 | SanDisk Sansa e260 MP3 Player
Gpdr 40
Try going to www.mustek.com/product-resources/driv...
Nov 08, 2007 | Goodmans GPDR40 Digital Media Player
Frozen white/stripy screen this time!!!!
press the power/menu button until the player turns off. after than perform recovery mode and try to update the firmware of the player to the latest one which i believe is .18A. :D
Aug 14, 2007 | SanDisk Sansa e250 MP3 Player
GPDR 40
1. you need to install the pc software 2. you need to connect the system to your pc via the usb cable 3. switch the system on - it should be seen as a mass storage. 4. Start PVR Console and run a disk checkup - this should run without error - run this twice. 5. Try the unit now - does it work? 6. if you still have problems you can replace the files in pvr data with the following:- http://mustek.com/product_resources/drivers/pvr-upgrades/pvrh140-datafiles/pvr-h140_restore_files.zip good luck Ian
Jul 13, 2007 | Goodmans GPDR40 Digital Media Player
Video trouble
Download latest Quicktime
Oct 01, 2006 | SanDisk Sansa e250 MP3 Player
Goodmans GPDR40 Digital Media Player Logo
121 people viewed this question
Top Goodmans Audio Players & Recorders Experts
Pavel Pranovich
Pavel Pranovich
Tom Chichester
Larry
Are you a Goodmans Audio Player and Recorder Expert? Answer questions, earn points and help others
