Question about Pantech C120 Cellular Phone
Pantech C120 Incoming calls vibrate but do not ring. Phone is set on vibrate and ring, and will not ring on this or on setting ring only.
  • 2 more comments
  • tuanp Jun 06, 2008
    I get no sound at all from the phone. Display shows the vibrate icon, even though I set it to ring. This phone is screwed up.
  • Anonymous Mar 13, 2014
    HOW TO SET VOLUMEN FOR INCOMING CALLS
  • Anonymous Mar 18, 2014
    I want my Nokia X to vibrate for incoming calls and message, how do i set this
  • Anonymous Mar 24, 2014
    vibrate option works for incoming texts and calls but ring option does not work. no sound
    Brigadier General:
  • 7,752 Answers
Change the speaker on the phones and also have the ringer check on the main-board.
Posted on Jun 24, 2008
Try holding down the asterick button (the star under the number 7) it has a little vibrating phone on it it always works for me
Posted on Jul 12, 2008
SOURCE:
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
Won't ring
you may have you phone set to a "silent" profile
you need to go into profiles and select a profile you like and then you can edit it (or create a new one)
May 29, 2009 | Pantech C120 Cellular Phone
Pantech c3oo wont ring
It is in vibrate mode...it drove me crazy too!
Simply press and hold the "*" key at the lower left to exit vibrate mode.
Apr 07, 2009 | Pantech C300 Cellular Phone
Will not ring
I dont receive phone calls and not ring
Jul 18, 2008 | Pantech C300 Cellular Phone
PHONE WILL NOT RING
Hi it sounds like your problem is that the call diverts are set to divert all calls what you need to do is goto settings then goto call settings then look for call divert settings what you need to do is cancel all diverts and then go through them one by one and just
activate divert if off (activating this one goes to ans phn if phn off
activate divert if busy ( goes to ans phn if your on phone call)
activate divert if out of reach (goes to ans phn if no signal)
After doing these settings then your phone should ring when someone calls you.
Before you activate any divert setting select cancel all diverts then get someone to ring you and make sure phone rings the screen will now display whos callind and the phone should also ring.
Let me know if you need further assistance ok let me know how you get on
Feb 15, 2008 | Pantech C120 Cellular Phone
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Jan 16, 2008 | Nokia 6288 Cellular Phone
Pantech c120, stuck on vibrate alert
press the * button and hold it down that should take it off vibrating mode
Dec 28, 2007 | Pantech C120 Cellular Phone
Rings when set to vibrate.
you may need to edit the 'settings' or 'details' for the vibrate profile. hope this helps :)
Oct 28, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Pantech C120 Cellular Phone Logo
533 people viewed this question
Top Pantech Cell Phones Experts
Marvin
Marvin
Abdul Mannan
Abdul Mannan
rebecca curry
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
