Volume digital distorted spikes in adat-xt20
I just got my adat xt-20 serviced for the tape transport, but i am still experiencing this nasty digital distortion spiking when nothing is coming into the inputs, it seems to be only happening on tracks 1,3,and 7...
Anyone experience this, and how did you remedy?
thx wayne
[email protected]
    Sergeant:
    Champion:
  • 319 Answers
Check your operations manual on proper grounding of power and input cables. High gain circuits are very sensitive to ground loops and can produce phantom noises. Also, static charges on input cables can do this as well.
Posted on Apr 23, 2008
SOURCE:
How to hook up the wires of Mackie CR-1604 mixer, to Alesis ADAT xt20 recorder
If memory serves correct you have rca and outs, 8 each. Using rca to 1/4" cords work the best. Connect each of your cords from the "in" on the alesis to the channel access 1 through 8 I believe to the first click. Run the "outs" from your alesis to channels 9 through 16. Use 9 through 16 as playback and 1 through 8 for instruments. This is one good way of doing it with our limited gear. Good luck!
Jun 01, 2014 | Mackie Cr 1604 16 Channel Mixer
What is the gas to oil mixture for a poulan xt 20t weed eater?
For the older XT20-T on the trimmer itself it states to add 8 oz. of oil per 1 gallon(128oz.) of fuel. This gives you a 16:1 fuel/oil ratio, NOT 40:1 which is the spec for the newer trimmers.
Aug 02, 2011 | Garden
Canon zr85 will not power with either a battery and/or dc power adater. Can I manually remove the cassette?
Unfortunately, the tape mechanism must be powered to remove the cassette. This will require disassembly to remove safely and can usually be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Nov 29, 2010 | Canon ZR85 Mini DV Digital Camcorder
The camcorder was dropped and the tape transport door is 'off kilter' and I can't open the door.
Tape mechanism problems are quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
Sep 29, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony dcr trv245e erroe code c32 20. I have had condensation issues with this camera in the past and now I cant eject the tape. can anyone help
The error code that your unit is now producing indicates that it is experiencing a tape transport problem - specifically that the takeup reel is leaving slack out of the cassette. This may have led to tape becoming caught in the mechanism and hence the cassette will not eject. This is one scenario although unfortunately it is not the only possibility.
The unit will probably need to go to a professional to have the cassette manually removed and the cause of the fault condition identified and rectified.
Jan 02, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
"prot" error message on Alesis ADAT 16 bit recorder
I heated the mechanical sensor switch with a hair dryer. Probably caused a contact point to expand just enough to close the circuit.
Dec 11, 2008 | Basf 938 DA-40 ADAT 16Bit format / Album...
Alesis lx20 type 2
send it to be serviced.
My adat lx20 keeps showing a error 2 and spits the tape back out, i chek the tape in my other adats and its fine. any suggestions?
Owain
Dec 24, 2007 | Quantegy ADAT: ADAT: 60 Minutes ADAT...
Tape torn near end. How to fix????
You'll have to open it up, but be very careful doing this. It can be done though, with a steady hand.
Nov 11, 2007 | Quantegy ADAT: ADAT: 60 Minutes ADAT...
65 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
