Question about Dryers
Kenmore Oasis Dryer, intermittantly stops running and displays an F45 fault code.
  • Anonymous Apr 24, 2009
    My Kenmore Elite dryer stops before my clothes are dry and the error code F45 flashes...what does this mean?????
  • 156 Answers
Problem with the interface board
Posted on Mar 19, 2008
SOURCE:
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Error code f 43 or 45?
The situations I have encountered that refered to a F43 or F45 error code, usually ended up having to have the control panel re[placed after a series of different checks such as blocked vents and electical issue Check your warranty If the dryer is fairly new it should be covered, Also if you orginally pruchased a maintenance or service contract with the item the control panel is definately covered.
Feb 27, 2011 | Kenmore Elite Oasis ST 6806 Electric Dryer
Error code F44 on sears kenmore elite oasis electric dryer.Doesn't seem to be cycling completely.
The F44 error code on this type of dryer indicates a blower motor control board failure. Since it happens only occasionally, then you could have a loose wiring connection or a partial obstruction in the blower housing. Complete details of the troubleshooting for this error code are included in this link of a previous answer: What does the fault code F44 indicate on my Kenmore Elite Oasis dryer?
I recommend that you unplug the dryer and check the wire harness connections if you are confident that you can safely access the internal dryer components. If you find a loose connection, then tightening it or plugging the harness securely into the connection will likely correct this problem.
May 08, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite oasis dryer model #110.6708 will not operate. flashes f-40. what does f-40 mean?
F40 = thermal fuse blown.
If the fuse is OK the error points to a communication problem between the machine control board and motor control board (check connectors).
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore oasis electric dryer beeps and displays code F45
We had this error on our machine for about a year before we finally got sick and tired of it. Our dryer was purchased in 2006.
Here is the solution: the code means there is an error on the thermistor. Our thermistor was loose, as were other electrical wires. My husband tightened up all the connections and the thermistor, and we have never had this error again.
However, we will never buy these machines again either, because we have had numerous other errors on the washer and dryer.
Nov 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis error code F41
I don't see this code often although I can steer you in a good direction, F41 to F47 is error codes for dual motor problems on oasis.
Jul 21, 2008 | Kenmore 67082 Electric Dryer
Kenmore Oasis HE 27062600 Fault code 50
Any solution? I have the same F50 error code.
Apr 29, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Dryers Logo
273 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
