Give your self about an hour and you'll easily have it done. Remove all screws and obvious retainers to the panel (usuall popped on press fittings) Thw window winder handle can be removed with a wide shoe lace or similar . It's retained by a horseshoe shaped spring clip. Use the lace to pull the clip in the opposite direction to the horseshoe clip and try not to loose it ! Pull on panel to remove,This should give you free acess to winder mountings and the glass retaining/mountion brackets. Disconnect glass and remove for safety. remove winder mechanism and reverse proceedure to re- assemble. Ensure all fittings are tight and good luck
Unfasten the bolts (1) and remove window regulator
To install:
NOTE:By removing window regulator motor, gearing shifts, it is not centered
For replacement part carrier assemblies, the gearing is secured in place with a cable tie (1)
