Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Junk Bought the $1,000 TV about 3 years ago in Sam's club. Last October tv started ghosting - diagnosed the conversion ic chip had failed - took tv to the closest Samsung authorized repair center in Watertown, NY. After a 2 month wait and $270 charge we got our tv back. Today after having the tv for approximately 3 months it started to ghost again... and we heard an immediate pop. There were then red, green colored lines in the center of the tv with black all around the outside and another loud pop with a burning electrical smell and then it all went black! Have tried to contact Samsung - all that can get a hold of is a incompetent person at a call center and makes it impossible to get in touch with Samsung directly. Wouldn't recommend anyone buy Samsung. Do you know how to get in touch with Samsung and not a call center?!
  • Samsung Master
  • 8,617 Answers
The only number that I have is this 800 number for support.
800-726-7864 . Watertown N.Y. Its been ages since I have heard that. I am from Potsdam in St.lawerence county origionally. You are probably going to be better off diagnosing and repairing the set on your own. how is your troubleshooting skills. Let me know if youd like a link for the service manual and some support to try and diagnose that set.
Posted on Mar 18, 2008
SOURCE:
My Panasonic TV HDTV Model PT-56TW53 - 52 inches / 1080i I bought the projection TV in October 2003.
This TV has reached well beyond its normal lifespan for the TV type and size. The new LED/LCD displays are so much better that you will wonder why you haven't replaced before now.
Jun 29, 2017 | Televison & Video
The left side of the picture has red and green stripes and ghost images. The right side does not have this problem, but the picture is not quite right. The convergence chips were replaced two years ago and...
That sounds like the convergence problem I had about a year ago, and like you, I replaced the convergence chips and that fixed the problem. It's cheaper to replace the chips if you do it yourself, but maybe not if you send it out for repair. If you can find an exact replacement board, that would fix it too, but I wouldn't necessarily expect it to last longer. The advice I read on replacing the convergence chips in my rear projection TV was that they would last 2 or 3 years and then need replacing again. So you're within that range.
Feb 27, 2010 | Sony KP-51WS500 51" Rear Projection...
PICTURE IS STRTING TO BEND AT THE TOP AND BOTTOM
This sounds like the most common thing that fails on projection TV's, regardless of the brand. The convergence circuit has two, or sometimes three STK IC chips mounted on heat sinks to drive the convergence yokes. They typically last anywhere from 5-10 years, then they fail. It sounds like in your case, the solder joints on the bottom of one of these chips may be failing and some fresh solder will make it go for a while. If it was my set, I would go ahead and replace both STK chips once I took the trouble to take it apart.
Jul 06, 2009 | Mitsubishi VS-55705 55" Rear Projection...
We have blue ghosts with brilliant colors
This sounds like the most common thing that fails on projection TV's, regardless of the brand. The convergence circuit has two STK392-110 IC chips mounted on heat sinks to drive the convergence yokes. They typically last anywhere from 5-10 years, then they fail. A more robust part is now available (STK392-150) as a direct drop-in replacement. My shop has installed these IC's in hundreds of projection sets and had fewer than 1% of them come back with repeat failures. Also check the following low-ohm feedback resistors to make sure they did not go out of tolerance:
  • RK42: 2.7
  • RK46: 2.2
  • RK58: 3.9
  • RK52: 3.3
  • RK50: 3.3
  • RK54: 2.2
Jan 25, 2009 | Hitachi 50UX52B/53K 50" Rear Projection...
I purchased an Insigna HDTV (or so I thought) at Best Buy a year ago, anticipating the February 09 conversion. I also bought a HD specific antenna, since I don't subscribe to either cable or the...
I was not aware that there are HD specific antennas. But, that aside, I don't know enough to answer without the model number of your set and information about the antenna, such as how you have it connected, is it amplified?
Best Buy is usually pretty good about helping with solutions. Have you called or visited a store? Be sure to ask for the Geek Squad person/s that are specifically assigned to TV's. Also most of their Dept heads are pretty knowledgeable concerning conversion and the associated problems. My apologies for not having a better answer.
Sam Bass
Nov 19, 2008 | Televison & Video
Panasonic 47wx53 covergence issues
Is the power indicator flashing three times? If so the Ics have shorted shutting the set down. You will need two STK392-110 convergence ICs. You can get replacement ICs at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Aug 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Green double image
you need to replace both convergence ICs they are both STK392-110 and you can get replacement ICs at the following link and they provide free step by step instructions with pictures so you can do the job yourself. Heres the link.
Jun 30, 2008 | JVC AV-65WP74 Rear Projection Television
Have a panasonic 47" HDL projection tv..under 5 years old model # pt-47wx53g, chassis Ap 825,manufactured August 2003 Purchased Oct. 2003. Have cable service..TV works fine until 2 weeks ago. Screen...
3 blinks means the convergence circuits are shutting the set down. Usually the convergence ICs will take care of the problem, but I would recommend getting the service manual from the following link, as they will provide you free support to help you diagnose why it wont start as usually the convergence ICs wont prevent a set from powering up, unless another component in the convergence circuit has failed.
Mar 24, 2008 | Televison & Video
1.5 days after replacing both IC chips the blue started ghosting again and then...
The biggest problem you stated yourself. You bought aftermarket type IC's. You should have been smarter and purchased the correct IC's for the set. All IC's are not alike, even with the same number on them. Aftermarket IC's are just that. Built in China or are factory rejects. You might get away with replacing the iC's again from a reliable dealer or you might have messed up the power supply in the meantime. Good Luck
Mar 02, 2008 | JVC AV-48WP30 48" Rear Projection...
Tv problem
The vertical sweep circuit has failed.
Can't say that its because of being stored, but it is a common problem on CRT TV's. Something in that circuit has failed: The IC chip, one of the electrolytic capacitors (actually those do dry out over time and may well be your problem) or the power source from the flyback transformer may be out. Some or all of these may be involved. The good news is that all these parts are cheap and this repair is always worth doing.
Hope that ya fix it!
Jan 03, 2008 | Televison & Video
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
212 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
