Question about HP Officejet Pro L7680 All-In-One Printer
Printing uneven When I print, the top left corner does not print fully. I replaced the ink and it is stilll doing it. It does it on copies too.
    Problem Solver:
  • 5 Answers
Take the printer in to a tech.
Posted on May 27, 2008
How do I change the ink in hp officejet 5510
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    Uneven printing
    You need to clean the cartridges and the print head. Remove the cartridges and clean the nozzles with a damp cloth, let it dry for a few minutes and then insert them back and now try to print a few pages, it should take about 5 - 6 prints before printing properly.
    Jan 26, 2010 | Lexmark X2690 All-In-One InkJet Printer
    Uneven printing]
    Your cartridge is not able to supply that density of ink for that number of lines of solid color.
    Could be any of the following:
    1. Dirt in the cartridge
    2. Low ink level
    3. Bad ink in a refilled cartridge
    Solution:
    1. Print 1 copy in "draft" mode to see if cartridge can keep up. If so, it is simply ink supply... Replace cartridge, refill cartridge.
    2. Run the "Clean" maintenance routine before trying to print a strong demand image.
    3. Replace the printer for a quality image device (laser is best, all others are less). Good quality HP is better in inkjets. Decent Lexmark is fair - but VERY expensive to own/run/maintain. Kodak is cheap enough to buy and keep filled. Reliability is a potential problem...
    Hope this provides some useable insight. -Jim
    Oct 23, 2009 | Computers & Internet
    How do i change ink?
    If iam not wrong you want to replace the Ink Cartridge. Please follow the below mentioned instruction.
    Regards,
    Shrey
    Oct 08, 2009 | HP Officejet 5510 All-In-One Thermal...
    Colour prints coming out like draft copies - i.e. faded
    Hello sir; It seem like you need to clean ink cell and print head, open top part let the cartridge move to the middle and the UNPLUG power cord you can easily to reach the ink cell to clean it.
    Aug 20, 2009 | Canon PIXMA MP210 InkJet Printer
    Epson stylus C88 makes black horizontal lines on the print
    This "banding" is caused by uneven ink flow through the print nozzles.
    Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three
    cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
    If you have already done lots of head cleans with no perfect results, are you sure you have good ink cartridges properly installed? The printer determines the amount of ink left in the cartridge by counting the number of ink "shots" when printing, head cleaning etc. This information is stored in the "chip" on the cartridge. Thus, it is not an actual measurement of the ink left, but an estimate calculated by subtracting the total shots from the original full ink quantity. This estimate can sometimes be grossly in error, usually due to a cartridge replacement not being carried out correctly. To eliminate this possibility, buy a new set of compatibles on E-Bay - they're very cheap. You can always re-use the old ones later if it turns out they DO have ink in them.
    If none of the above works, then you may have blocked print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid
    comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any black ink on the nozzle check, then there is hope! Repeat the process until you get a full black nozzle check. If nothing, repeat the process once more.
    If still nothing, post a new comment detailing what you have done and the results.
    Apr 04, 2009 | Epson Stylus C88 InkJet Photo Printer
    Printer does not make black copies, it will print colored copies but not black kodak 5300 aio printer will not print in black. ink cartridge new.
    Remove the black and color ink cartridges.
    Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
    Place the printhead right back into the printer and push straight back on the back wall.
    You should hear a loud snap.
    Replace the ink cartridges which should snap as well.
    Close the printer.
    After about a minute or so the printer will ask you to do a calibration.
    Insert a paper and press start.
    Scan the calibration sheet.
    After that, in the menu, do a printhead clean.
    Do one basic and one deep.
    Print a demo sheet to see if anything has changed.
    If the picture looks better, continue to do cleans.
    In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
    The whole process is short and free.
    The number for Kodak AiO Support is 1 800 421 6699.
    Aug 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
    How do you change an ink cartridge on a HP officejet 5510 printer?
    1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
    2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
    3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
    4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
    Aug 11, 2008 | Office Equipment & Supplies
    HP Officejet Pro L7680 All-In-One Printer Logo
    63 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
