Whirlpool Compact Washer won't come on
I have a three year old compact washer that was installed permanently a year and a half ago and was working great. On Saturday I was doing laundry and the washer would not turn on. I pushed the buttons repeatedly and after a minute it came on and washed that load fine. The next load I put in it would not come on so I gave up for awhile and later I tried pushing the buttons and opening and closing the lid several time. It came on and started the cycle fine and when it came to the rinse cycle it filled part way and stopped and will not start again. The cycle light is flashing, but the washer will not do anything. I had to wring the clothes out by hand and I cannot get the washer to come on to drain. I checked both ends of the hose that is hooked up to the water and they are clear. Any idea what is wrong?
  • 185 Answers
Sounds like the lid switch
Posted on Mar 26, 2008
My portable/compact Whirlpool washer drains, but won't spin water out
Check on Youtube for removal of the pump clips and motor clips. It really only takes a flat screw driver for each clip and a 1/4 socket too for the motor clips, as you tilt the machine back to get at the parts.
Feb 20, 2014 | Whirlpool Washing Machines
Washer will wash but won't spin after wash to finish load
Does the water drain after it finishes the wash before the spin is supposed to start? If yes then it can be that the timer is faulty or the spin windings in the motor have burnt out.Does the pump work at all when this has happened, or is the machine completely dead?Let me know please.I also need to know whether it's a digitaly controlled machine or works with a mechanical switch.
Apr 18, 2013 | Whirlpool LCE4332PQ 22" Portable Compact...
Had a Razr which worked great for three years, the...
it might have,contact www.phoenixtec.ca fill out the contact form and they will respond very fast
May 13, 2010 | Cell Phones
Whirlpool wshser-dryer: water won't drain, cycles won't start
You need to give more info in order for a diagnosis. Is this a compact stack unit or an all -in -one unit or an interconnected washer/dryer pair ? Is it front load or top load washer ? What do you mean by "dry cycle"? Is that dryer cycle or is it washer cycle without water ?
Usually when water cannot be drained it is a bad coupling connector on the motor drive, or a bad or clogged pump (small socks have been known to get sucked in an lodged in the pumps); in either case you need a good mechanic or a service person to handle the repair because it requires opening up the shell of the unit and getting to the motor/pump assembly.As always, disconnect the power cord before diving into the unit. Good Luck, Macgivor.
Sep 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Same F1 Fault Code
The only action you can take is to raise your voice with other people who have faced a same issue with Whirlpool :-
http://www.petitiononline.com/cabrio08/petition.html
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Apr 09, 2009 | Whirlpool WFC7500VW Washer
Advice on compact front-load washing machines
If you can get a whirlpool lhwoo5op They had less problems with that model then the other 2:)
Mar 28, 2009 | Whirlpool LHW0050PQ Front Load Washer
WHIRLPOOL ULTIMATE CARE II MAKES YELLOW BROWN STAINS ON LIGHT COLOR CLOTHES
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
Sep 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Avanti w752p compact washer
Try Googling (Avanti)(W752P)(manual) without parens.
Sep 05, 2017 | Avanti W752P Top Load Washer
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
