Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Trans will not disengage
Greetings. This is a great resource. I appreciate your presence of the web. My WUC II started making a sound that can best be described as the agitator mechanism being slightly engaged during the spin cycle. About a week ago, the top half of the agitator (the screw) stop operating, even though the paddle assembly onthe bottom did function normally. Now, the machine will not spin. Placing the unit in the spin mode, one can see the basket "trying" to move, but the trans seems to be engaged yet, but not moving.
The motor works fine. and there's no problems with the pump ***'y. I've removed the outer cabinet, pump and motor to access the mechanisms. I can not easily move the inned coupling. I really can't afford a new or replacement unit. I'm pretty handy and feel with you guidance, I can affect the repair myself--providing nothing is actually broken.
Thank you
Chris Baker
  • Whirlpool Master
  • 2,651 Answers
Either you have something stuck betwwen the two tubs(ie. a sock. ) preventing the tub from free spinning.or there is a clutch mounted on top of the transmission not engaging, as far the agitator not spinning correctly sounds liek the agitaor dawgs are stripped preventing proper agitaing(bottom of agitator works fine but upper portion free spins both ways without resistance?? correct??
Posted on Mar 20, 2008
91 lexus ls400 starter engages with key in "on" position, starts then will not disengage
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link. Best Manuals
Jun 13, 2014 | 1991 Lexus LS 400
Metal on metal noise
most likely the throw out bearing is at fault. when you push the clutch a spinning bearing pushes the clutch plate away from the flywheel disengaging trans so you can switch gears. the transmission has to come away from the engine to fix it.
Jul 04, 2017 | Toyota Corolla Cars & Trucks
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
Can I tow a 1985 ford bronco II 4x4 with hubs and a 5 speed manual trans. without disconnecting the drive line
yes if you make sure the front hubs are disengaged(turn little hub releases in middle of the wheel,man trans is ok auto not ok you do need to remove the drive shaft of an auto not man
Oct 26, 2009 | 1985 Ford Bronco II
Trans. shifting problem
try a fluid and filter change and also a modulator valve and make sure you have vaccume going too it
Feb 27, 2009 | 1995 GMC Sierra C1500
Fujitsu P 2040 DVD choppy player
make sure that you have the latest drivers for your video card and audio cards turn down the visual effects of windows xp to best performance and check all background programs and see whats being used up
Jan 04, 2009 | Fujitsu LifeBook P2040 Notebook
1999 Durango Automatic Transmission
sounds like a stuck valve. I'm still new to transmission stuff so I could be wrong. he could probably get a transmission rebuild book and maybe just do it himself. it would be the cheapest unless you knows someone
Oct 04, 2008 | 1999 Dodge Durango
check the lid switch, if it is ok go to the pump and see if anythig is in it, if nothing there motor issue
Apr 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
102 people viewed this question
Dan Webster
Dan Webster
Sal De
