RCA T19408 19 in. TV/VCR Combo Logo
Posted on Mar 18, 2008
Only goes to channel 13
My tv only recieves 13 channels when plugged into cable when it should recieve over 70. my other tv gets all the channels so i know it is the tv. what should i do?
  • 1 more comment
  • Anonymous Apr 18, 2008
    I can program up to Ch. 25..
  • jmlsparky77 Jun 13, 2008
    my tv only goes up to channel 13 when hooked up to cable
  • ntchou Jul 23, 2008
    yes, same problem, it does not picking all cable channels.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1248
Points
It probably has to do with a setting in your menu. Usually it is the antenna category. Change it to Cable or CATV.
Have a cable box on 19inch lcd sansui, and can't recieve my digital channels?
Is it supported by the TV? Are you licensed to receive the Digital channels, i.e., is it a payable channel?
1helpful
My remote scanned all the tv channels (Cable TV, TV, DTV and Cable DTV). The channels that do not show up now are the Cable TV channels. They are there if I type in the channel number but the remote...
U are recieving an using DTV Free AIR broadcasting tv signal wright,get a better antena like a roof or a newly design digital antena for uses.This problems dose not happen to cable or sattellite services,i know this because their broadcasting tv signal frequencies are very strong and very high ranges of a broadcasting signal output for their recieving boxes.
I have connected the tv to cableand I can only recieve channels 2,4,5,9 & 13. How do I set up the tv to receive the remainder of the channels? Thank you
do a channle auto scan, you need to select CATV in order to scan for cable channels. after the scanning process, all the channels you can get should be on your set.
Can not get tv to reach channels from 2 to 70
Sounds like you need a set-top box from the cable company.  You hook that up to your TV, tune the TV to Channel 3 or 4, and use the set-top box to tune in all the channels.
1helpful
I can't get all the channels using the remote
I enter the menu button, channel, add, and it begin to add the channels for cable.
1helpful
Making the TV VHF plus UHF cable ready
If your tv tuner on vhf only goes to channel 13 you will not recieve uhf channels if you are hooked to cable tv. You can do a search for mid band to uhf converters (converts uhf to vhf).We used to use them in the early 80's. Even if you can find one it will only go to channel 22.
3helpful
2answers
How to hook up cable and get more channels than 2-13????
Change setting in menu to cable from tv or antenna. May be in channel setup menu.
Getting the speakers to work with the TV
Yupp(depending on how old your stuff is) I will assume your using cable and using your tv to switch the channels. Look at the back of your tv there should be a audio output, plug some RCAs (red, and white) into the designated spot and now look on the back of your reciever, it should have a tv input, if not just a input. After that is done turn on the tv and put the reciever on the channel that you plugged it in. For example if you plugged the rcas into Tv input...then you would set the reciever to TV
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
