Question about JVC KD-G230 CD Player
Unit will not turn on
Bought a new JVC KD-230 yesterday from Circit City. Removed old unit and was very careful to match all the right color combinations of wires from power cord to wiring harness. No mix ups, honest. Each is well connected with a wire nut. Unit is well grounded and antennae wire is inserted. Unit will not react at all, as though there is no power. Tried the reset. No help. Removed the unit, reinstalled the old one (at least I used to get AM and FM from it) but now it too acts like the new unit; NOTHING. Also, now suddenlt the electric door locks will only work if the ignition is turned on, whereas used to work without the key anywhere near the ignition.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
This seems like you have accidently rewired part of your electrics. You may have wired the power wire into the wrong place, and also wired your electric door locks into your accessories. YOU NEED TO BACKTRACK. Find you doorlock wiring and get it back to a constant power supply. Best bet is to wire your power wire of unit to cigarette lighter by splicing the wires or jacking the outlet at the back. Here is a guide to install your stereo. Following those steps and see if you went wrong somewhere.
http://www.ehow.com/how_5829_wire-car-stereo.html
Posted on Mar 19, 2008
Why does my jvc kd-r526 reset to factory default everytime i turn it off
Try connecting the yellow wire to a constant power source. That is, a source that still has power when the key is turned off. The yellow wire controls the memory of the radio.
Jun 02, 2011 | JVC KD-R800 Car CD/ MP3 Player
Installing Jvc KD-R610 into 02 Nissan Frontier, where I have removed older JVC. Using old harness, but blue wire labels do not match... One says "amp power" and other says "power...
well it sound like your ground wire is not connected the properly way this wire is black make sure
the other 3 are connect right are Yellow is constant power ,Red is acc.ingnition,Blue is the remote.
that would complite your conection done.
Dec 27, 2010 | JVC AM FM CD DET FACE CAR STEREO
Jvc kd-g340 rear speakers not working. I recently bought the car with this unit installed. I noticed that there is a l/r cable, power, ground in the trunk which means there was probably a subwoofer...
check the wires in the back of the stereo if not then make sure the back speakers are not hooked up to a internal amp and if it is make sure that it is not blown
Mar 31, 2010 | JVC KD-G340 Car CD/ MP3 Player
Need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Nov 22, 2009 | JVC KD-G340 Car CD/ MP3 Player
Unmarked wires
your jvc is pretty standard on hook ups.red wire is on a keyed power wire,black is chasis ground, blue is remote wire to amp.yellow also keyed power wire.speaker wires there will be 8,usually whit violet so on. white solid for exzamle is + white with black stripe is - you can figure out front and rear with an old speaker and buy fading front to rear on your head unit youll know front and rears.same for left and right.did you look on the unit usually the have the wiring diagram on the unit itself.mine all do
Jun 21, 2009 | JVC KD-S580 CD Player
Promblem wiring to my car
GO TO WWW.CRUTCHFIELD.COM AND THEY WILL SELL YOU AN ADAPTER SO YOU DON'T HAVE TO CUT ANY WIRES ON YOUR CAR
Jun 19, 2008 | JVC KD-SC800 CD Player
Instlling kd-avx1
You can download the manual direct from jvc on their website, all instructions and drawings are present
Apr 29, 2008 | JVC KD-AVX1 Car DVD Player
Jvc kd-pdr31
I believe You have to have the right auxillary connection to plug it in -- looks like in the lower right hand corner if you are looking directly at the unit.
Apr 17, 2008 | JVC KD-PDR30 CD Player
JVC KD-AVX2 new installation will not power up
your set could have damage after powering it up and connecting speakers.have the tech repair it.good luck.
Apr 01, 2007 | JVC KD-AVX2 Car DVD Player
JVC KD-G230 CD Player Logo
168 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
