Question about Zanussi TC7102W Electric Dryer
Electric dryer i have a kenmore electric dryer 80 series. it turns but does not blow hot air. if it is the thermostat, where is it? my email is herved11@yahoo.com
  • 156 Answers
The thermostate is in most cases dryer has the lint screen going in the top its in the back also the thermo fuse is there ck it both one on canister and ck element if is lint screen on the inside remove bottom panel off its all right there
Posted on Mar 19, 2008
I have a Kenmore 80 series heavy duty dryer that is not giving out much heat.What should I be looking for to solve the problem?
Is it gas or electrric? Either one i would check the dryer vent hoses. Check the lint trap as well. The lint trp is the exit for the hot air to circulate. Sometimes if clogged with lint these dryers could go either way they could over heat and cause a fire or cause the element or thermostat to fail. The electric dryers have a thermostat and a heating element. Those tend to go bad. Back panel should be taken off and unplug unit check.
Apr 03, 2011 | Kenmore Dryers
I own a Kenmore dryer 80 series and the dryer works; however, its not blowing out hot air?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Kenmore Dryers
I have a Kenmore 80 series dryer 110.74852400 and it is not blowing hot air
We have the same problem. Did you ever solve your issue? Stuff like this usually means a thermostat, in my experience. $17 part
Feb 28, 2010 | Kenmore Washing Machines
I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Feb 02, 2010 | Kenmore 64742 Electric Dryer
Hello. I have a Kenmore series 80 dryer approx 7
Sounds like your problem may be with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Oct 19, 2009 | Kenmore Dryers
KENMORE 80 SERIES NOT HEATING
you need to check the heating element and the thermal fuse in the back of the dryer, they should be their. do you have an ohme meter, if not barrow one or you can pick one up cheep and lowes or homedepo .
Dec 13, 2008 | Kenmore 659 Electric Dryer
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
2004 kenmore 80 series dryer all electric
ckd thermal fuse on element housing ..then element for continuity but also could be timer contacts or switch on motor but ck for burnt wires and 220 volts at back of dryer
Jul 21, 2008 | Dryers
broken belt 341241 part number
Apr 09, 2008 | Maytag HYE3658AY Electric Dryer
Zanussi TC7102W Electric Dryer Logo
66 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Marvin
Marvin
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
