Question about Motorola Mobility E815
Blue tooth motorola e815 cannot find device on my blue tooth
  • Smillerdad Apr 09, 2008
    I have one E815 with two blank screens.  I tried to use my wife's retired E815 which doesn't charge as a temp but found bluetooth not working either so I can't sync my numbers into the temp phone, but at least I can see the screen.  Verizon offers no good replacement for this phone.  I'd switch carriers but everyone in my world is on Verizon for in-calling.
    So, I need:
    1.  How to fix blank screen
    2.  How to restore bluetooth function.
    Any assistance would be apprecaited.  Thanks.
  • 552 Answers
Check this link for your phone.
Posted on Apr 25, 2008
I have a Motorola E815 Alltel cell phone and was wondering if I could somehow make this phone compatible with Verizon since they are my current carrier? How do I switch this Alltel E815 to Verizon?
Hi Dawn Lynn Martens,
You can take the device to Verizon to see if they can activate it with their frequency. Since they handle CDMA devices as the Motorola E815.
Best Regards,
Katya
Motorola Support
Aug 16, 2015 | Motorola Mobility e815 for Verizon /...
What is my pass key for H350
motorola uses two pin pairing codes for their blue tooth devices they are as follows,0000,or 1234 there are two other codes for blue tooth devices as well they are as follows 1111,or 9999 glad to be of assistance.
Feb 26, 2011 | Motorola Mobility H350 Wireless Headset
Unable to put phone into pair mode motorola hs810 to a i phone 3g
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Feb 22, 2011 | Motorola Mobility HS810 Consumer Headset
My LG Shine phone will not pair up with my new Motorola Bluetooth device. (T505) I've tried everything!!
Motorola blue-tooth devices are mostly meant for Motorola phones. This particular device is restricted to be used by Motorola phones. No matter how hard you try the devices will not pair because they are not compatible.
There are certain blue-tooth devices which are universally acceptable by all types of mobile phones but the MotoRokr T505 as it is dubbed by Motorola is restricted to Motorola phones.
Sorry for any inconveniences.
Please do rate the service delivery on this question answered.
Jan 03, 2011 | Motorola Mobility MOTOROKR T505
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
Can't bond Samsung bluetooth(WEP 200)with my Motorola A1200 Ming
Try this (from the manual)
2 Press and hold the Multi-Function button until
the indicator light turns on in blue
(approximately 8 seconds).
Oct 31, 2008 | Motorola Mobility MING A1200
Water damaged motorola e815
We do it with lots of patience. We clean all the corrosion by emersing the board into alchahol, use a tooth brush to clean the corosion. then heating it up in a special "oven" . Then we replace any parts that are beyond repair, like LCD;s and mic's. check my profile if you need help
Jan 24, 2008 | Motorola Mobility E815
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Putting pics on computer
Yes, of course. You have 3 options, blue tooth, usb and memory card reader.
May 22, 2007 | Motorola Mobility E815
Motorola Mobility E815 Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
