Philips Magnavox 27MS343S 27" TV Logo
Posted on Mar 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Volume limiter How do I change a volume limit on a Magnovox tv?
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on Mar 20, 2008
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2175058
Points
14133
Unfortunately, this model does not have a volume equalizer other than volume + and - . There are other models of Magnavox that have Night mode, Delta Volume, and other sound control features, but this one just doesn't have those features. Sorry.
Is it possible to limit the volumn so that it cannot be put above 33 on the scale either from remote or on side of TV? Tried unlocking parental control, setting volumn and then relocking. Didnt work
volume limiting is self defeating because of the various volumes from different shows and different section of the shows. so there will not be a volume limiting switch/ mode on your set.
Volume wont turn up on my mp3 - volume too low
How to Reset the Volume Limit on the iPod Nano
Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume.
Instructions
1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
3 Select "Playback" from the menu choices that show up.
4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on.
5 Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Tips & Warnings
If you set up a combination and forget it, you can reset your iPod Nano and start over again. Resetting will not lose any of your downloads, but you will need to restore or reset many of the settings you initially chose when you first set up your iPod.
Changing the volume limits on your iPod Nano covers everything on your player, but the sound levels for songs, audio books and shows will vary based on how they were recorded.
1helpful
How to remove volume limit on eu ipod nano 5g
You can set the maximum volume limit by going to settings then playback and then volume limit. This will show you the current volume limit, use the click wheel to select the maximum volume limit and then press the centre button to set the limit. Hope this helps.
1helpful
How to you change the volume
System Settings --->> Volume. Select Normal or High, and then press Select button. Normal is a volume limit, High turns off the volume limit.
CANNOT FIND UNLOCKING CODE FOR VOLUME LIMITER ON IPOD CLASSIC BLACK 120GB
this should help you below. If you have set a password on the volume limit and forgot the password please let me know cause you will then have to remove the password or restore the device. This is only one step in trying to remove the volume limit it may work or it may not and you will have to use another method. But please tell me if this method works and if it doesnt i will instruct you on where to go from here. To set the maximum volume limit for iPod classic: 1 Choose Settings > Volume Limit. The volume control shows the current volume. 2 Use the Click Wheel to select the maximum volume limit. You can press Play to hear the currently selected song play while you select the maximum volume limit. 3 Press Play/Pause to set the maximum volume limit. A triangle on the volume bar indicates the maximum volume limit. 4 Press the Menu button to accept the maximum volume limit without requiring a combination to change it. Or, on the Enter Combination screen, set a combination to require that the combination be entered to change the maximum volume limit. If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
1helpful
2answers
How do i over-ride or reset the maximum volume limit on the nano 4g
ok maximum volume on the ipod will only work if you change it yourself. if you havent tried this yet, turn on your ipod then select settings then select volume limit and set it to whatever you want. if this doesnt work you can plug in your ipod and open up itunes and change it from there. the way you do this is right click on the song and click get info in the tabs select options and then you can set the volume limit there as well u can aplify the volume or change lower it
1helpful
32 inch tv goes from normal sound during program to extreme loud
May be a defect but, if you notice the sound changes with different channels or movies or HD or Standard, look for a volume limiter control button in the menu setup under audio control. Sometimes the menu has a control that you can turn on to limit different volume levels during the shows origination.
Limiting max volume on a Philips TV ??
This is usual done by a volume limiter. There are many tvs that have them but if it is not displayed in the sound settings menu I would safely say that the tv does not have this feature.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
