Question about Hitachi 50V500 50 in. HD-Ready LCD Television
I replaced the burnt out lamp,not working !!!
The exact same thing happened to me.The bulb went I ordered one online, its a philips but the original was manufactured in Belgium,the new one in China.It comes on for 5 seconds then the picture and sound shut down.Once that happens the blue power light blinks for approx 20 seconds then it starts again and shuts down within a couple seconds.It does this over and over.When I push the power button to turn it off the lamp light comes on. Could it be a bad bulb...perhaps drawing too much current?
  • notgivinup Apr 06, 2008
    I only purchased the bulb...I am using the old housing but thanks. I convinced,after much debating with the online store I bought my bulb from to send me another bulb hoping it was bad...I'll find out this week..
  • 50 Answers
This may sound crazy. If you still have the old lamp. Put new lamp in old housing, and try that.
Posted on Mar 31, 2008
Xl 2400 replacement bulb---dim after replacement
did you use a genuine sony replacement bulb or aftermarket? Often the aftermarket lamps are not up to par with the OEM versions.
Nov 01, 2012 | Televison & Video
Lamp bulb replacment
much cheaper to do it yourself, go online put in your tv's model number and seach for thr lamp and make sure you order the entire lamp assembly, on the back of your tv there is a door open and take out old lamp so you know what you are ordering, and when replacing the new lamp amke sure not to touch the lamp
Aug 12, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My Optoma HD72 projector operates for about 1 minute and then shuts off. I kept my old bulb around "just in case", I've replaced the bulb with the old one and have the same problem.
The problem is not over-heating. The Optoma HD72 has a known problem that Optoma won't advertise. The lamp driver is faulty. They simply have to replace the lamp driver. I purchased a spare lamp with my original purchase. I had the exact same experience as you at around 1200 hours on the lamp in ECO mode. I used the spare lamp. Same thing happened at about 1200 hours. I had a friend at Optoma. he confided to me the problem. I sent it in and they replaced the lamp driver at no charge. I got another 800 hours out of the first lamp and am now using my second lamp and have about 600 hours on it. The pic quality is so good with this projector (used Digital Video Essentials to calibrate) that I'll just order a bare lamp or two and use the existing lamp housings when I need a new bulb.
Apr 12, 2010 | Optoma H30 Multimedia Projector
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
Commander.
4. To change the Data Value, press 3 or 6 on the Remote
Commander.
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
memory.
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
easyab
ConvergenceRepair.com
__________________
Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
MY TV TURNS ON AND STAYS ON FOR 5SECONDS AND THEN THE SCREEN TURNS BLACK BUT CAN STILL HEAR THE SHOW PLAYING. TURNED IT OFF AND EVEN UNPLUGGED IT FOR ABOUT 5 MINUTES, BUT STILL THE SAME THING HAPPENS.
the lamp is likely bad .. they only work a few thousand hours .. then must be replaced .. your lamp can cost a couple of hundred (maybe even more if bought locally) .. here is one for less if you have someone handy that can change it.......
http://www.purelandsupply.com/50PL9126D-37-Bulb-Philips-DLP-TV-Bulbs.html
..... of course make sure power is off (unplugged) and make sure things are not hot .. there is usually a little cubby in the back where the lamp is located .. you an see what the lamp looks like at the above URL .. dont get finger prints on the bulb . that will cause it to crack when hot .. if you are unable to change the bulb then a call to philips service should do the trick. make sure you ask what the bulb replacement and labor will cost ..
Jan 27, 2010 | Philips 50PL9126D/37B 50" DLP TV
What if your tv needs a new projection lamp
I purchased my Sony bulb from BulbsOutlet.com and it was the best shopping experience ever. The customer service was impeccable, the rep. Jay was amazing and bent over backwards to do whatever it took to resolve any questions or concerns I had. This company is AWESOME and I highly recommend them to ANYONE. I will definitely buy from them again. Thanks BulbsOutlet!
Nov 13, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Wrong model number listed in my original question
I gave you exact and correct lamp part number of KDF-E55A20 and explained in previous reply that there is no difference between XL-2200 and XL-2200U lamp. both are same, first on came with new TV and second one is its replacement number.
KV-36FV26 is CRT TV and has no lamp inside.
May 18, 2009 | Sony KV-36FV26 TV
Maytag MMV5165AAS work surface light won't work. I bought a new light and replaced the old one but it still will not turn on. THe microwave display goes thought the cycle of High, Low, Off but nothing...
If the lamp socket has power (and it's the right voltage) and the replacement lamp is the correct one and tests good, then the trouble is in the socket. It may have been damaged when the original lamp went "poof." Check for damaged contacts (burnt or broken off). Also, make sure you're seating the lamp correctly in the socket. If the bulb is a push-and-turn ("bayonet") type, you may be facing it the wrong way and it's not going all the way in.
Nov 11, 2008 | Maytag MMV5165 Microwave Oven
Pt-50lc13
I fixed my TV. As I said, the TV would come on and work normally for about 1 minute. Then, it would turn off and the red power LED would blink continuously with the fan running, indefinitely. One more thing I did not mention previously is that the LAMP led on the front panel would blink once every 4 to 5 seconds.
After reading many different blogs, I went for the cheap fix first. I purchased the Ballast repair kit, Panasonic P/N LSUC0022. $21. It required opening up the ballast unit and replacing some components on the PCB. I noticed that some of the values of the components were different than the original ones. Unfortunately, the symptoms after this repair were the same. Oh well - no harm done. Perhaps improved it for the long run.
Next thing to try was the bulb. A costly thing to try, but an extra buld won't go to waste if I get the TV working.
Much to my surprise, this did the trick. Works fine now. The bulb had 1600 hours on it.
By the way, I went the less expensive route for the bulb. I purchased the bulb only - not the bulb with the enclosure. It was very easy to do, and much less expensive. I also purchased a Philips brand bulb, which is supposed to be much better than the original. If you decide to go the "bulb only" route, I highly recommed getting it here http://www.discount-merchant.com/Panasonic-TY-LA1500-Replacement-Lamp-bare-bulb-p/panasonic_ty-la1500_lamp_1.htm&Click=1683. This buld includes the wires and connectors, and requires only a screwdriver. This company also offers a Philips bulb with the entire enclosure. Don't get a bulb only that requires cutting wires and soldering!
I did eventually get a service manual. The troubleshooting chart for the LED blink pattern I had indicated the following:
"Wait until the lamp has cooled off. Confirm that the Thermal Fuse Unit is not open. Still NG, replace the Lamp. Still NG, replace the Ballast C.B.A. Still NG, replace the Main C.B.A."
Thanks to the person who responded! Your kindness inspired me to respond back with my results....
Aug 26, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
110 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
