E drive problems
Code 37. does not recognize E drive
    Problem Solver:
  • 18 Answers
Hi, have you checked to see that the ide cable is firmly pushed into the drive you can try replacing the cable or trying it with a different one. Try unistalling the drivers for it and reinstaling e.g. from the manfacturers website. Let me know whats the outcome, hope this has helped. Thanks
Onlinepc-Fix
lee
Posted on Mar 18, 2008
Doesn't recognize replacement hard drive
What is the type of IC regulator voltage on power supply board Onkyo DV-SP502?
Jan 17, 2014 | Philips DVDR3575H/37
SONY PDW-F355 error code 02 F 37
There was a firmware update (2.01) to correct this. May 14, 2012
Servo drive function is improved as follows.
The servo drive is now adjusted correctly, and the adjustment no longer results in offset values from characteristic variations in the alignment disc (PFD23A-RS).
Previously, when not adjusted correctly, inserted discs were not recognized, DRV ADJ Err (Error 6F-E00/6F-E80) appeared, and the unit stopped operating.
Apr 15, 2013 | Sony PDW-F355 DV Camcorder
Jeep is dieing while driving down the road --showing codes 37 and 43
Check your plugs, wires cap and rotor. Also check the coil output. You may have an engine misfire caused by one of those items. Also...have you had any problems starting the car that requires you to move the shifter in order to get the starter to engage? 37 code may be related to that.
Mar 26, 2011 | Jeep Grand Cherokee Cars & Trucks
I have a 1995 dodge ram 1500 5.9 automatice 2 wheel drive and it dumps gas into the carb with a code 37 coming up. could the intake gasket cause this problem? i have replaced the coolant temp sensor, the...
code - 37 TCC brake switch circuit error. this is the torque converter clutch. Open or shorted condition detected in the torque converter part throttle unlock solenoid control circuit
  • For turbocharged engines , code 37 will be triggered when the baro-read solenoid circuit is open or shorted.
  • For normally aspirated (non turbo) engines with automatic transmissions, code 37 will be triggered when the Part Throttle Unlock (PTU) solenoid circuit is open or shorted.
  • For normally aspirated cars with manual transmissions, code 37 is sometimes set for no apparent reason.
This is detected when the ECU doesn’t sense near 0vdc or 12vdc at the relay when the solenoid is turned on or off. When code 37 is thrown the power limited light will not be lit and the system will not enter limp mode.
Aug 08, 2010 | 1995 Dodge Ram
Code 37 on dvd drive
The Code 37 error may occur when the concerned device is not connected to the system correctly and when its driver is faulty. A code 10 error is common when you add or remove USB devices or video & sound cards to and from your PC. When these errors occur, you may receive the error message given below.
Windows cannot initialize the device driver for this hardware. (Code 37)
To resolve code 37 errors, first ensure that your device is properly connected to your system. For instance, check all the cables of your printer or check that your sound or video adaptor is properly seated in its slot.
Try to remove and reinstall the device, and run the Add New Hardware Wizard from the Control Panel to see if Windows detects and installs it. If this does not resolve the issue, then update the device driver by performing the following steps:
1. Open Control Panel and select System.
2. In the System Properties dialog box, select Hardware tab, and then click on the Device Manager tab.
3. Scroll down the Device Manager window and identify the faulty hardware from the list.
4. Right-click on the hardware and select Update Driver.
5. Follow the screen instructions to resolve the error.
If these steps do not resolve your error, then the problem might be with your device. Get it checked by an authorized technician.
Aug 04, 2009 | Dell DVD-rom DVD Drive
Win98
Is the drive recognized in the bios? The bios in a machine that old probably has an 8.4Gb limit. Go to the motherboard manufacturers web site and look for a bios update. It's unlikely you will find an update to recognize the entire drive. Did you try to partition and format the drive?
Oct 31, 2008 | Computers & Internet
Pioneer dvd-rw dvr-k17a
I fixed it my self, redownloaded my Windows and repaired it.
Sep 08, 2008 | Pioneer DVR-107D DVD±RW Burner
GOGEAR SA 3345/37 - Computer is not recognizing player as a player
The 5125 recognizes copyright-encryption and has an Audiobook feature
The 3345 does not recognize copyright-encryption, and does not support audiobooks - if you want some laughs - the file system in the 3345 has an Audible folder, but the player does not recognize Audible - it was a design fluke
Philips 2008 models are a step down for the 2007 models, if you ask me
Jul 25, 2008 | Philips GOGEAR SA6045 MP3 Player
Unit does not recognize usb flash drive.
Use a 2GB or less compatible memory card - Sandisk is the best bet.
Feb 19, 2008 | Philips DVDR3575H/37
Computers & Internet Logo
Alun Cox
David Payne
David Payne
