Question about Xerox 8200/DP Thermal Printer
Print head error? (13.004.43)
Can you tell me if this is only going to be fixed by a print head replacement?  Thanks.  I got this at an auction and I have changed the halogen lamps.  Hope you can help me. Cheers, Mark
  • redvoll Mar 23, 2008
    Thanks for your update.  Ventilation check OK.  I am pretty sure the ink was Tektronix/Xerox stock (is there any way to tell from extra ink blocks that are in the feeder?
    I will try the troubleshooting listed.  Is there a recommended way to get hardened wax/ink off the little trays in the print head?  The left "tub" is clogged (indicates the left jet stack diagnosis) but I can't see how to clear it without damaging parts.  Thanks, Mark
    President:
  • 2,072 Answers
The Printer's Front Panel Displays Printer Error - Contact Service; Report Fault 13,004.43 Cause:
The left jet stack heater is not heating at all, or is heating too slowly TRY FIRST (Solutions without parts): 1. Poor ventilation. - Make sure printer has 6 inches minimum of clearance on all sides. 2. reseat the cables to the printhead. TROUBLESHOOTING TIPS AND HINTS: 1. added drum maintenance parts for damage control. replace as needed if worn or broken. PARTS:Parts are listed in the order of highest probability for repair. NUMBER QTY DESCRIPTION PROBABILITY% MODEL S/N FROM S/N TO S/N 650411200 1 *PRINT HEAD ASSY; . 367051501 2 FOLLOWER,CAM; DM CAM,SAFETY CONTROLLED, QTY 1 650428800 1 FRU, CLUTCH/ANTI-ROTATION COLLAR 351105301 1 GUIDE; DRAWER ASSY,DM RIGHT 351105102 1 GUIDE ASSEMBLY; DM DRAWER,LEFT,SAFETY CONTROLLED REPAIR/INSPECT/PREVENT PROCEDURE: 1. Clean pick rollers only when ink or debris is visible. 2. Clean feed rollers, exit rollers and guides only when ink or debris is visible. 3. Inspect cap/wipe/purge gasket and wiper blade. 4. Check for cooked or discolored inks; if necessary, flush out ink. 5. Inspect and clean the drum maintenance blade and the rapid release guide. Check print quality; if necessary, perform clean for light stripes. 6. Check cleanliness of interior and exterior of printer, including fans; if necessary, clean (dust or vacuum) these areas. 7. Report the use of Non-Tektronix/Xerox ink. 8. Review proper operation of printer.
Posted on Mar 23, 2008
  • Rick Kasper Mar 24, 2008
    Don't worry about the ink sticks your using. Really would be unusual for that to be a problem.
    What the issue is, is the left side of the print head itself is not warming or sensing that it is warming.
    I would first of all try, this. You have to remove both the left and right covers, then the ink loader. ( Where the sticks are). Under that is the print head area. What is used are ribbon cables that are simply pressed into stampons for connectors. I would try reseating the cables to the print head. Sadly though, the most likely problem is that the heating element inside the print head had opened and is not heating. That needs to heat to keep the ink melted.
    Sometimes you can find good used print heads on E-bay.
    I wouldn't bother removing the hardened ink. That is only in the jet tub because the heater stopped working while it was full and solidified while it was full.
    Reading you may have already reseated the connectors.
    I honestly would think that it is extremely likely the print head has failed. Wish I could offer you more hope of a cheap repair.
    The printers that actually make the highest quality color copy are the emulsion toners. Somehow they learned how to align the particles of toner, and at 2400 x 2400 resolution they are incredible. And less than 1000 dollars.
    Not exactly sure why I mentioned that LOL. But they have really impressed me for quality of a dry ink printer ....
    I forgot to mention. in the menu under trouble shooting, there is a service diagnostic area you can enter and monitor the print head heaters and see which ones are and are not working.
    Once you enter the diagnostic mode, you have to scroll to fine the heater monitor area.
    I was going to mention that earlier but simply forgot.
6ya staff
SOURCE:
How can I fix no cartridge error on brother mfc-465cn
It sounds like it may actually be the "print head" which is what the carts fit into. These can and will go bad. Sometimes you can find replacements on ebay etc. But you need to make sure it is exactly the same part number. There could also be a number of other issues, the cart contacts could be dirty or damaged (another print head issue resolved by replacing), counterfeit cartridge, bad cart. These are the most common, but not the ONLY issues that can cause your problems. I'd check prices for replacement print head vs. new printer.
Jul 18, 2014 | Brother MFC-465CN InkJet Printer
I have a 2004 kia optima lx, my head lightes only last for 6 months then i have to replace them except this time they actually lasted all most a year
If the are just bulb replacements and halogen anything that touches them will make them go out including a finger print.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jeff_24365d731679262d
Dec 12, 2013 | Kia 2004 Optima LX V6
How to change headlight 2003the x type Jaguar
look inside owners manual in glove compartment look up bulb replacement in the back index it will show and tell you how to replace headlight bulbs. be sure to wear clean gloves, because headlight bulbs or halogen type bulbs, if oil from hands or skin touch the halogen bulb it will cause halogen light bulb overheat and blow out.you can go by auto parts store when you buy new headlight bulb the salesperson will go out to vechicle and replace headlight bulb for you wont charge you any thing.just charge you for the headlight bulb.
Feb 12, 2012 | 2003 Jaguar X-Type
Installing d2r sylvania lamp in 2001 acura
look in owners manual back index for bulb replacement, it will show and tell you how to replace light bulbs.make sure you wear clean glove when handling halogen head light bulbs because oils from skin will cause halogen bulbs to over heat and blow out, halogen bulbs not cheap.
Jan 03, 2012 | Cars & Trucks
Replacing headlights
look in owners manual in back index for bulbs replacement it will show and tell you how to remove replace head light bulbs also wear clean gloves when handling the head light halogen bulbs because oils from skin or fingers will cause halogen bulbs to over heat and blow.
Nov 29, 2011 | 2007 Pontiac Torrent AWD
Driver side low beam bulb replacement
LOOK INSIDE OWNERS MANUAL IN GLOVE COMPARTMENT.LOOK IN THE BACK INDEX FOR BULB REPLACEMENT.IT WILL SHOW AND TELL YOU HOW TO REPLACE BULB.BE SURE TO WEAR CLEAN LATEX GLOVES WHEN HANDLING HALOGEN HEAD LIGHT BULBS.BECAUSE OILS FROM FINGERS OR HANDS WILL CAUSE HALOGEN BULBS TO OVER HEAT AND BLOW OUT.
Jun 23, 2011 | 2007 Saab 9-3 Aero Convertible
How do have you change an headlight bulb?
LOOK IN YOUR GLOVE COMPARTMENT FOR THE OWNERS MANUAL. LOOK IN THE BACK INDEX OF MANUAL LOOK UP BULB REPLACEMENT. IT WILL SHOW AND TELL YOU HOW TO REPLACE HEAD LIGHT BULBS. YOU NEED TO WEAR CLEAN LATEX GLOVES WHEN CHANGING HALOGEN BULBS BECAUSE OILS FROM FINGERS AND HANDS WILL CAUSE THE HALOGEN HEADLIGHT BULBS TO OVER HEAT AND BLOW OUT. HALOGEN BULBS ARE EXPENSIVE THEY COST FROM $10.00 - $20.00 BE SURE TO WEAR CLEAN GLOVES WHEN HANDLING THEM.
Jun 18, 2011 | 2003 Oldsmobile Alero
I put new lite bulbs in and changed the head lite switch but it still blowing the head lites
you have halogen bulbs when replacing them you have to wear clean gloves on hands .your hands has oil on them it will cause bulbs to over heat and blow. you need to wear new cloth gloves.when replacing halogen bulbs.
Dec 03, 2009 | 2001 Hyundai Tiburon
HP D135 PRINT error
I am sorry the print head goes out on the B And W on these things quite frequently. however you can go to www.hp.com amd go threw thier secdualed way of testing the print head but am sure you will find it defective. I had one and it was a problem. B e aware they have a new head that replaces the old head that lasts much longer.
Oct 05, 2009 | HP OfficeJet D135 All-In-One InkJet...
Printhead
What problem or fault code are you experiencing?
I also am assuming you don't have a maintenance agreement on the machine?
I can tell you in detail how to replace that print head. It really isn't that difficult. Just a bit time consuming. I would guess an hour and a half .
But lets start with whats going on with the printer .Maybe it can be fixed much easier and far less expensively. That print head is $450 wholesale. SOooooooooo lets see if we can get it fixed for you without a print head ok.
Jul 25, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Open Questions:
** SCAM WARNING ** >>>>>>>>>>>>>>>>>>>>> TOSHIBA PRINTER TECHNICAL SUPPORT pHoNe @{+1800.8O3=1O69} Number USA @#$! ** SCAM WARNING ** >>>>>>>>>>>>>>>>>>>>> TOSHIBA PRINTER TECHNICAL SUPPORT Number @+18OO*803;1O69 to resolve all TOSHIBA PRINTER products. TOSHIBA PRINTER is an American multinational company which was founded by Michael TOSHIBA PRINTER using its company headquarters in Round Rock, United States of America. Contact TOSHIBA PRINTER for Setup & Installation TOSHIBA PRINTER Setup Free & Installation TOSHIBA PRINTER CUSTOMER FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for TOSHIBA PRINTER Connect, TOSHIBA PRINTER CUSTOMER Free Phone Number you'll be searching out TOSHIBA PRINTER Connect setup as well. So, here we're with all cthe setup process and for your to TOSHIBA PRINTER Connect. Get TOSHIBA PRINTER Setup Instant Free TOSHIBA PRINTER CUSTOMER FREE Phone Number Usually, the setup CUSTOMERnique takes a number of time. One CUSTOMERnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't CUSTOMER-savvy. Let us undergo the method of TOSHIBA PRINTER Connect setup for Windows and for Mac. So, right here we go vishall
Oct 22, 2019 | Toshiba Office Equipment & Supplies
See all Xerox 8200/DP Thermal Printer Questions
Xerox 8200/DP Thermal Printer Logo
209 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
