Question about Sanyo 24KS62R Cool Mini Split Air Conditioner
Stand By Mode
My split system air conditioner/heater Sayo Ductless System remains in the stand by mode when I turn the heat on. The problem on occurs in one of the units. Help!
  • 86 Answers
1. use remote properly
2.first off the unit then again the unit
3 if same problem change remote by new one
Posted on Mar 28, 2008
The system cannot be turned on. Need a tech.
[PDF]Service Manual - Quietside
https://quietside.com/max/.../Service%20Manual_MAX%20Series.pdf
Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.
Sep 28, 2015 | Samsung AQV36JA Classic 36000 BTU Single...
I have a Mitsubishi heat pump that runs well but the outdoor unit does not defrost what could be the problem.
Why does my heat pump ice up in Winter?
Heat pumps naturally ice-up in the winter. It is normal for the entire coil to be covered in a white frost and even light ice, during cold weather conditions. However, it is bad for the entire unit to be encased in ice. This indicates ductless heat pump problems which should be addressed quickly to save energy and avoid serious damage to your ductless unit. These systems should periodically go into a defrost cycle. This keeps the unit running efficiently. If the coils are blocked by ice, proper heat transfer between the coil and the outside air will not occur.
How does the defrost mode work?
When the mini split heat pump goes into defrost, the reversing valve inside of the outdoor unit is energized, switching the system from heat to the air conditioning mode. The outdoor coil becomes the hot, the indoor coil becomes cold, and both - the outdoor and indoor fans shut off. This allows the outdoor coil to melt accumulated ice. When the built-in micro-computer analyzes that all ice have been melted, the heat pump heating system goes back to heating mode.
sanyo-mini-split-defrost.pngA cloud of water vapor may be seen rising over the outdoor unit and a "whoosh" sound can be heard as the refrigerant reverses direction. The entire process usually takes up to 10 minutes (depending on conditions).
How often does the system goes into defrost mode?
Ductless mini-split heat pumps have different ways of determining when to go into defrost. The built-in microcomputer determines outdoor temperature, refrigerant pressures, and several other factors. In colder temperatures the system will go into defrost more often than in warmer.
If a ductless mini split heat pump is severely iced-up in the winter it is possible that it isn't defrosting (though there could be many other causes). Let the manufacturer certified technician check your system
Oct 29, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
1.ac is not producing heat at roomtemperature. 2.how far and near should indool and outdoor be.
1.To get proper heat mode should be in "Heat" . and temp setting must be +5 than your room temp.
2. Minimum 4 mtr pipe length and maximum of 15 mtrs.
Dec 26, 2010 | GE Quiet-Aire Ductless Split System Air...
A/c with heat pump. only runs by-pass mode no cool
If you remove the coil from the rev valve it will burn out the coil. So do not do this. Now if the charge is low (static charge to me means at rest or at start up with no load) the rev valve cannot reverse its self. It has to have enough refrigerant to make the reversing valve switch possession
By by pass mode do you mean in the heating mode?.
If this has helped you any please rate me as high as you can if you need more information please post and I'll try answer more, but give me as much information as you can. type of refrigerant, both fans operational, clean filters, all ducts open, what kind of heating electric or gas, your locality : coastal, inland, humidity....
May 16, 2009 | GE Quiet-Aire Ductless Heat Pump Split...
Need to know what the icons stand for on remote control for Toshiba Split System Air Conditioner. Don't have a manual?
Generally all the symbols on each unit are the same. The snowflake does cooling, the sun does heating, the fan does fan only mode, the water droplet does dehumidify and the arrows means automatic mode. The increasing bars refers to the fan speed.
Mat
Apr 25, 2009 | Continental Electric CE-AC7581 Ductless...
My GE ductless system is not heating properly and trips breaker
Call them yourself. Let them know your compressor is tripping your breakers. Also, ask how to obtain parts for your system. It's rediculous an hvac tech cannot get advise from ge.
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
New install. 40 seconds on. 20 seconds off.
Its normal that the air coming out is warm cause you set it to heat mode. Check your setting temperature, it is normal for the unit to shutdown when it will attain the setting temperature and operate when the temperature is lower than the setting temperature(heat mode).
Mar 05, 2008 | GE Quiet-Aire Ductless Split System Air...
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Sanyo 24KS62R Cool Mini Split Air Conditioner Logo
432 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
