Question about Cameras
Digital Camera film is stuck - Cameras
    Novelist:
  • 142 Answers
Digital cameras don't have film, they use a memory card. Depending on the type of memory card, there's either a button right next to it that you push in and that will eject the memory card (ie: Compact flash), or if it's an SD card, just push in the card until it clicks... then the card will be spring activated and come out. Let me know if that helps. If not, repost the brand and model of camera.
Posted on Mar 18, 2008
Film advance lever stuck
Do you have a film in the camera? If so is it all exposed? Best thing to do is press the film rewind button and try the lever at the same time - this will eliminate stuck film issues as it removes film tension from the system. If this does not solve the issue then you need someone to have a closer look.
Feb 07, 2014 | Canon F1-N 35mm SLR Camera
Film broke of and is stuck in the film guide where I can't get at it...
You are in the digital solutions asking about a film camera. I might be able to help if I knew the make and model of the camera you have.
Dec 28, 2010 | Cameras
Film roll stuck in my camera canon eos lx
The Canon EOS is a digital line of cameras from what I can tell. If that is the case, then there is no film in the camera.
However, assuming that you actually have a 35mm camera with film stuck in it, the following should work for. You don't indicate what you mean by stuck, but the standard solution for removing 35mm film from a camera is to take the camera into a dark room, open the back of the camera and remove the film and canister, being careful to not tear the film. While still in the dark room, place the film into a light proof bag to avoid spoiling it when it goes into the light. You can then contact a local photo processor about their ability to process the loose film. Make sure that the bag is clearly marked to avoid having someone open it by accident, spoiling the film in the light. If you can't find someone locally who can process the film, Kodak can do it for you in Rochester, New York. Contact them for instructions on shipping the film.
If you don't care about the film or pictures it may contain, feel free to simply open the camera and remove the cansiter and film, discard it, and start over.
Nov 14, 2010 | Canon Photography
The film magazine stuck in the Canone EOS 10 camera, never happened that before, i could easily insert and remove the film. it's rewinded, luckily, but I need a new one to put there, + I'm afraid if I...
Nikon N75 or Canon EOS 10????????
How is the film stuck? Is the rear door stuck? Does the film door open?
As long as you do not damage the film canister, the film will be ok. If the door opens and the film is rewound, use something to pry out the top of the canister from the camera. Then you can remove the film.
Even a film roll of 36 should not get stuck. Check the cartridge are for anything sticky. Sometimes these older cameras get some sticky residue from decaying foam in the shutter area. This would be a good time to send it in for CLA - Clean, Lubricate, Adjust.
My own EOS 10 had that problem. If you can't get the film out, the repair shop will do that for you.
Jan 20, 2010 | Nikon N75 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Pentax super 100 35 mm camera shutter is stuck
gabe529; This doesn't appear to be a digital camera, so this can't be a problem generic to all digitals! This is a film camera. Have you tried new batteries? Have you checked your battery polarity in the camera? Have you taken your film out and wound the take-up lever once or twice, or will it not advance? There are many situations where a 35mm camera shutter won't work. We may provide a better answer if your post could be more specific (i.e. what were you doing before the shutter quit - loading film, taking a snapshot, checking shutter release while the back is open?) Hope this helps somewhat.
Jul 24, 2008 | Cameras
Camera issues
Check your mirror lock up switch. This function is used for long exposures locking the mirror in the up position to reduce vibration before the shutter is released, but you will not be able to use the view finder.
May 23, 2007 | Canon EOS-Rebel G QD Film Camera
Cameras Logo
52 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
