Question about Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 Same as everyone else. Need color wheel but customer will not put out the $$ for a new light engine. What's your method for repairing the old one? Thanks, Jim [email protected]
  • 80 Answers
SOURCE:
I have a sharp 56 inch that has an inoperable color wheel. It is very loud and the picture does not show at all. What can I do?
What has to be done is the color wheel will need changed out before we can go any furthur. While your at it change the lamp.
This link will include all you need to know about the issue and is very helpful in the repair, they say it much better than I could and pictures to boot!
If you find this helpful, a vote on the thumbs up would be greatly appreciated for this free advice and if you need more assistance please let me know. Thanks.
http://www.instructables.com/id/How-to-fix-your-Sharp-56DR650-with-color-wheel-iss/
Aug 22, 2011 | Sharp 56DR650 56" Rear Projection HDTV
I have a Sharp 56DR650 Rear Pro. TV. w/ a LOUD color wheel motor
If the color wheel is making noise then its best to replace it and not try to repair it, Unfortunatley the wheel is not available by itself and a complete optic block part # 9NK3797086200...Be careful when taking the bock apart as it runs $900.00
Oct 14, 2009 | Sharp 56DR650 56" Rear Projection HDTV
I have a Sharp 56DR650, red power light turns off.
Engine block(color wheel) needs replacing approx $650 total
Aug 09, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 won't turn on
the 32 message indicates lamp issues. Buy a new lamp with new cage and that should fix the problem.
May 30, 2009 | Sharp 56DR650 Television
Sharp 56dr650 Dlp colorwheel for Mike miaer
I have a Sharp 56dr650. The color wheel bearing failed. Sharp cares not for its customers and won't even respond to my pleads for help in obtaining the replacement. So, with that said, I went to ebay and bought a vizio color wheel (Omega TV in Hollywood, FL). Color wheel is incorrect and colors are all blue as is, so I pulled the color wheel off and did the same from the old one-BIG note, the wheels are glass and fragile, DO NOT BREAK the old color wheel! I viced the old bearing and carefully worked the shaft out of the bearing (it is snapped into the bearing). The vice distorted the old bearing but it was trash anyway. The new bearing, I broke the new color wheel off and viced the shaft. I then pulled the old bearing from the wheel. I then carefully push the old shaft and color wheel into the new bearing (you will know when it snaps in place) asserting preasure ONLY on the metal center hub with my thumb. I had to file a new slot on the cast housing as the ribbon connector is about 1/2 inch shorter on the new bearing. I installed and it all works great!!! Saved from tossing a $2,000 plus tv out! SHAME ON SHARP! Never buy another Sharp product!
Feb 15, 2008 | Sharp 56DR650 56" Rear Projection HDTV
I have the color wheels in stock let me know if you need them
Sharp 56DR650 Color Wheel.
Encompass parts distribution has more than 50. I order off the internet. Part number and brand name is viv 3250701500 vivitek. With shipping about $119.00. I think the television is worth repairing. Look for people who are dumping the sets.Mark
Dec 26, 2007 | Sharp 56DR650 56" Rear Projection HDTV
My TV loudly hums when I turn it on
Ok, I just picked one of these babies up this past weekend. It was cheap, so I didn't bother with the research once i saw that it powered on and seemed to work.
It was sold very cheap because it was throwing codes, which the previous owner was told was a cooling fan. Due to my computer hardware experience, I decided to trace what the problem was. The 2 accessible fans were working flawlessly and silently, the 3rd fan (going to the input components) was stopped due to dust bunnies. A can of air and a complete cleanout solved all issues with the cooling fan codes. The loud annoying hum is the motor that turns the color wheel. Since I had everything out of the TV anyway, I decided to trace the sound which is actually behind the color wheel and sounds more like a bearing or mis-balance in the spinning motor. The color wheel itself is in perfect condition.
In the meantime....annoying hums are fixed simply by turning the volume on your tv or sound system up - it's barely noticable during normal operation and is only really annoying when initally turning it on.
Hope this helps someone.
May 06, 2007 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 56" Rear Projection HDTV Logo
85 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
