I have installed the linksys software but can't create a wireless connection with my laptop even though I know it is wireless enabled. During installation, there is a Wireless Connection Failure.
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    What model Linksys are you using? Do you know that your laptop is capable of wireless or that the wireless is enabled? Pleas provide me with this info and I'll get right back to you. Thanks.
    Guru:
  • 377 Answers
Hi dear
try this
  1. Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP key are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their web site or when you purchase access you will be provided the information.
  2. Ensure you have a firewall program installed and running. This will protect your data.
  3. Start up your laptop and once booted, look for the Wi-Fi network icon in the bottom right of the screen.
  4. Click on the Wifi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click on the Properties tab.
  6. The next window will show the type of networking card installed. Click on the Wireless Networks tab.
  8. Once the Wireless Network Connection Properties window is open you will have two options depending on how you set up your laptop.
    • If you do not see any networks listed in Preferred or Available networks, you will have to manually add the SSID. Click on Add. You will have to enter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available networks box.
    • I have installed the linksys - 4d25eb5.jpgttp://i.fixya.net/uploads/images/4d25eb5.jpg" alt="4d25eb5.jpg" class="h_mi" />
    • If you see the correct SSID showing in the Available Networks, then you need to click on Configure in order to enter the WEP key if thaI have installed the linksys - 92752af.jpgred.
  9. In the next window, enter the SSID for the Wi-Fi network you want to access. Make sure you do not have CAPS lock or NUM lock while entering the information. If a network key is required, click on "Data Encryption and then enter the Network key you have been provided with. Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly a message I have installed the linksys - fccfda9.jpg and you will need to re-enter the key.
  11. Next go to Start - and where it says Connect To click on that and you should see choices like in tI have installed the linksys - 34b0a7b.jpgbelow. Click on Wireless Network Connection and it should work.
There are occasions when the connection doesn't work, in these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall program disabled, you change your settings. If your firewall program is not the problem check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
oke post in me back
i hope this usefull for you
thanks
cropp
Posted on Mar 19, 2008
The Linksys software doesn't seem to connect with the adapter. Windows recognizes the wireless connection. Link information shows "No association with access point." Site survey doesn't show any sites...
go here and check your configuration against this page at Linksys
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=5a0bd60abc0d4d8b968b42db95fffd59_4543.xml&pid=97&slnid=4
Apr 23, 2010 | Linksys WPC54G Wireless-G Notebook Adapter...
I cannot get my Brother 9840cdw to communicate with the Linksys wrt160n. PC cannot locate printer even though both are wired connections. I do not know the ssid on the linksys and tried the automatic...
You will need to check the wireless settings of the router.
Do you have any other wireless computer working ?
try changing the channel of the wireless network.
You will need to open the set up interface of the router.
Click Here for more info
Oct 22, 2009 | Linksys WRT160N Wireless Router
Wireless Router Causes XP PRO to Crash. I just purchase a Linksys WRT110 wireless router and installed it using the EasyLink setup cd. The install went OK but Windows XP PRO immediately crashed and...
Have you unisntalled all the Linksys sofftware through add/remove software. I had a similar problem with an IOGEAR Bluetooth transceiver, I did the setup from the CD, my laptop (Dell C640) blue screened each time. I uninstalled all the IOGEAR software and my laptop stopped blue screening. I never installed the software for a wireless router, I always use the WEB interface and my life is my simplier.
Jun 02, 2009 | Linksys Wireless-G WRT54G Router
Lenovo laptop cannot seem to find the linksys wireless g. we have two WIFI at the office one is linksys VOIP (secure) and linksys wireless G (unsecure). why is it that lenovo laptop only sees the secure...
make sure that the linksys VOIP(secure) router is broadcasting it's SSID or signal, otherwise it will not reflect even if you refresh the wireless network. If the router is broadcasting SSID but the lenovo laptop is not detecting it, try to re-install the wireless software for the laptop using the software from lenovo.com, just click Support then Downloads and drivers.
May 13, 2009 | Linksys Wireless-G Broadband Router
My password is "wrong' whenever I try to connect on my laptop
That's firmware problem on your router. Try to download the latest firmware for you router from www.linksys.com/download then load the latest firmware. After successfully updated the firmware, you need to hard reset the router by pressing the reset button for 20 seconds then unplug the power for 10 seconds and plug it back in. You will need to reconfigure the wireless settings.
Apr 15, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Installed Linksys G router successfully on my own computer. Now I'm trying to connect a second computer for wireless internet and I'm getting an error message saying: The wizard cannot create a wireless...
1 make sure the wireless adapter is on.. (laptops have on off buttons for wireless)
2 make sure the drivers are installed for card in laptop
if not reinstall them..
check in device manager look for ! or ? in there if you see unknown device or cannot start messages reinstalled that device..
Feb 18, 2009 | Linksys Wireless-G Broadband Router
I installed the software for the router but i can't use my laptop wireless
your Wifi is not Enable Yet,
you have to login into your Linksys and go to Wi-fi and Enable your Mac address for your Router..
Feb 02, 2009 | Linksys WMP300N Pre-802.11n Wireless...
Server not found No internet connection
Does the access point you are trying to connect to have encryption enabled?
Aug 28, 2008 | Linksys Wireless-G Broadband Router
Installation
Make sure your router is being detected by computer
after detection associate it, If network key requested enter the network key has been entered during installation. Also Check your computer's wireless device status if its on and enabled.
If issue persist please post question with complete details like Model of your computer and router, especially symptoms that you are getting.
Good Luck
Dec 30, 2007 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
73 people viewed this question
Alun Cox
David Payne
David Payne
