Washmachine is broke
My washmachine all of suddon stoped the spinning cycle and has a burning rubber smell when i went to check on it. my main question is how do i get the front cover off to take a look at the insides? lawrence boyd (859)-866-0765
    Novelist:
  • 142 Answers
Depending on the washer, you don't have to remove the front. If you need, you can easier remove the rear, but most of the machines I've worked on had direct access from the bottom without having to remove any doors at all. It sounds like you fried a clutch mechanism or if it's belt driven maybe just the belt has broken. If it's a belt, no brainer... replace the belt. If it's the clutch mechanism, you might consider the cost of the mechanism - vs - replacement of the machine.
Posted on Mar 18, 2008
My machine didn't spin properly on the delicate cycle, it span on the rinse and spin cycle but smelled really bad, like burning rubber. It is quite old should I get it checked or get rid of it?
rubber smell could be a slipping drive belt
have a technician check it out and get a quote
if the quote is more than 25% the price of a new unit then make that decision
Jun 04, 2017 | Washing Machines
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
Smell rubber burning when on spin cycle
This sounds like the belt is slipping, which will burn the rubber and give you that smell. Replace the belt and be sure the tension pulley spins easy.
Jan 07, 2010 | Westinghouse Washing Machines
Top Load making noise. Wash cycle finished, open
bad lid switch.coupling broke and rubber burning or trans locked up
Nov 15, 2009 | Refrigerators
Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
May 18, 2009 | Maytag Dependable Care LAT9416
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Your washer has brake problems you need a qualified repair person
Apr 02, 2009 | Washing Machines
WILLNOT SPIN OR AGGITATE/IT WILL DRAIN
Just because the rubber part of the coupler isn't shreded doesn't mean that the plastic parts are not broke... There are three stems that protrude from the plastic parts of the drive coupler,and mesh with the rubber section of the coupler... the stems may be broke off... If you smell rubber burning then I would say almost 99% of the time it's a bad drive coupler...If the coupler is not broke and the rubber section is alright then you have a bad transmission... Most likely the main drive gear is bad... Since you said that you can spin the tub by hand, indicates that the brake system is alright, and nothing is caught between the inner and outer tubs... You can rule out a lid switch problem, cause the washer would agitate even with a broken lid switch, but it would not spin..since the machine make any kind of different sound when you run it Like a high pitch squeal or grinding noise?
check the lid switch see if it's not broke... wasn't the lid switch, but I got to thinking it will agitate at the first part of the wash cycle, but when it goes into the slower speed wash, if your lid switch is broke, then it won't agitate or spin...
Feb 10, 2009 | Kenmore Washing Machines
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
265 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
