Yamaha ypg 625 keyboard -rattle
I am looking for Yamaha factory authorized repair on my daughter's ypg 625 keyboard. We live in the south part of St. Louis county, MO Where can I go to find this info? A couple of her keys rattle when she lets up on the key. None of the others do that. It should be covered under warranty at this point.
  • geanann Mar 18, 2008
    this is not a receiver it is a musical keyboard
  • Anonymous Mar 14, 2014
    yamaha ypg 235
  • 97 Answers
I just went to the Yamaha website and found it under service/support. You might use one of the contact methods first to verify/register your keyboard before taking in for service.
http://www.yamaha.com/yamahavgn/CDA/Service/ServicerLocator/0,,VNM%3DLIVE,00.html
please rate solution. thanks.
Posted on Mar 18, 2008
Rattling keyboard
Call Yamaha at 714-522-9000 to find local dristubators/ liscend yamaha dealers. You may also visit the yamaha website.
Feb 18, 2014 | Yamaha YPG-625 (YPG625) Digital Piano
No sound on one key
That's very annoying! The keys press on to a contact strip running the length of the keyboard. Over time this wears out and notes can either stop being dynamic or stop playing altogether. You can buy the strip off ebay and have a go replacing it yourself - not too expensive. I paid someone 50pounds to supply and fit one to a 61-note keyboard.
Dec 18, 2013 | Yamaha YPG-625 (YPG625) Digital Piano
No power. voltage converter putting out 13 VDC. ON/OFF switch works. Any suggestions?
Inspect if the power input socket of The keyboard it may have a loose soldering or a cold one in one of the tips and may need to be
resoldered
Dec 29, 2012 | Yamaha YPG-625 (YPG625) Digital Piano
Rhythm accompaniment does not play. Start button flashes 3 green then 1 red. Began when someone randomly pushed number buttons on the key pad.
Do an initialization (factory reset) by holding the HIGHEST WHITE key down and turning on the power. Hold the key for an extended time until display confirms initialization complete. This will restore unit to factory defaults.
Jul 14, 2011 | Yamaha YPG-625 (YPG625) Digital Piano
I asked for help on a Yamaha keyboard. The solution was posted on an e-mail address that is not accessible. What do I do to either get my solution or get my money back
I don't know what the original problem was but here is your service manual:
http://elektrotanya.com/yamaha_dgx-620_ypg-625.pdf/download.html
Scroll down to "get manual" and click on it to download a PDF file of the service manual.
Ignore other download links for viewers etc... If you have trouble, contact me at fredy2 at aol.com with YPG in the subject line.
Hello, i spilt some smoothie on my Yamaha YPG-625s keys. The keys sound better now but i just want to properly clean the inside. How can i do this?
It is a lot of work to open and access the key contacts. Here is your service manual:
Scroll down to "get manual" and click on it to download. Ignore other download links on the page as they are for viewers and other software.
Jul 10, 2011 | Yamaha YPG-625 (YPG625) Digital Piano
Reboot instructions for a Yamaha YPG 625 piano? One fingered chords won't function, nor will the sequencer start from the keyboard. Thanks! ****
Read about initialization on page 61 of your user manual. This is a factory reset. There are two procedures there. If you don't have the manual download it here:
www.yamaha.com/yamahavgn/.../ypg_525_eng_manual.pdf
May 04, 2011 | Yamaha Sk88 Keyboard Survival Kit For...
I have a Yamaha YPG-525. Everything is working except the LCD screen. It turns on, but doesn't display anything... I had this problem once before when I didn't use the keyboard for a while, but it ended...
I have the same problem, mine is Yamaha YPG-625. This seems to be a common problem with Yamaha keyboards. I opened the 100 screws in the back, separated the main board from the display unit which is under it if you flip the keyboard upside down, to verify if there was any loose wires, nothing of the sort.
It is so frustrating, the keyboard is working fine but it is hard to navigate because the display is not functioning. Yamaha should do a recall as this is obviously something wrong with the keyboard happenning to a lot of people
Jan 08, 2010 | Yamaha Full-Size Keyboard
What needs to be removed from my Yamaha YPG-625 to
DO NOT open the case unless you are aware of and comfortable with the fact that you could _destroy_ your piano. Easily.
Observe appropriate anti-static precautions. It should go without saying that this is an electronic repair, and dangerous voltages may exist inside the case.
1. Remove the stand if you have one
2. Lay the keyboard upside down (bottom up) on workbench
3. Remove all 90+ screws from the bottom of the chassis, including the 14 inside the speaker compartments
4. Carefully lift up on the bottom case part, taking not to damage the speaker lines
5. Unplug speaker connector and set lower case aside
6. LCD is mounted beneath main logic board
9in the center), my problem lies elsewhere, but competent and cautious service technique should lead you where you need. I would strongly recommend replacing the LCD assembly module, unless you are experienced in LCD repair.
Jul 06, 2009 | Yamaha Full-Size Keyboard
496 people viewed this question
 Grubhead
Grubhead
