Question about Whirlpool LER5636P Electric Dryer
Whirlpool Dryer Dryer was running, I grabbed the lint tray to clean it while it was running... all of a sudden some sort of vacuum kicked in and before I could get the lint tray out, it sucked the lint outside and now, I can't put the lint filter back in where it goes?? It's like some sort of barrier is there now??? I've tried turning it to the off position and everything?? PLEASE HELP !!!
    President:
  • Whirlpool Master
  • 2,651 Answers
Sound like something fell down theslot, now preventing the filter form going back in. , its a direct chute down to the blower wheel, not to bad to access, youll need to remove the 2 screws on top , and hte n from behind drop back panel and youl seee the channel right ther probaly 5 screws to relaease it and you can look through and retrieve what has fallen. TURN OFF POWER FIRST
Posted on Mar 19, 2008
My Whirlpool Duet dryer lint screen will not go back in after being cleaned. It sticks out about 1/2 inch more than usual. Please advise.
Something is lodged in the dryer in the way, grab a flashlight and some hot dog tongs and, well, I'm sure you know what comes next.
Mar 21, 2017 | Whirlpool Dryers
Whirlpool Clean Touch Model LGL88580000
You can check for suction by pulling out the lint screen and holding a piece of paper over it while the dryer is running. If there is suction then it all works correctly. If there is no suction, then there is a clog somewhere inside. You can clear the clog with a long bottle brush or with an attachment from a vacuum cleaner to get inside. If all looks good and still no lint on the screen, the screen may be too short for the dryer and could be a wrong screen for it.
Dec 18, 2007 | Whirlpool LGQ9858P Gas Dryer
I have a whirlpool washer/dryer and cannot find out how to clean out the lint under the lint trap. There is quite a bit collected there.
Blow it out with compressed air or buy a spider web brush and put it down there to grab the lint.
Jan 06, 2017 | Whirlpool Dryers
We are having to run the dryer several times for med. load to day and I just noticed a slight burning smell. Can this be repaired and at wht possibl cost?
i would guess it is lint that is trapped inside the dryer, you will need to take the cabinet off and clean with a brush and a vacuum:
http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
Jan 09, 2011 | Whirlpool Inglis IP8200 Dryer
Whirlpool gas dryer WGD5540SQ it is getting power, drum does not turn, just hums when I push start button. I checked for blown circuit breaker, i' ve cleaned lint tray and checked vent to outside. I've...
there is a reset button on the motor more then likely it tripped, there are actually two one resets the other trips, but here is a website it will help with the dissemblance of the dryer, Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Oct 19, 2010 | Whirlpool WED5520SQ Gas Dryer
Where is the lint trap on the front loader
There is no lint trap. There is a coin catcher on the pump. The design of the wash action on a front loader is such there is less lint than on standard machines. One of the bennies of the design.
Eric
May 20, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
My Whirlpool duet dryers lint screen in the dryer don't seem to catch the lint anymore but, the varmet screen on the hood is clogging all of the sudden. We bought it in August and installed new stove pipe...
OK. to get this working again you want to get the vacuum in where the lint holder is.... then let it run and see if that works but im sure you might have to spend about 10 bucks for a new net
Dec 21, 2009 | Whirlpool Dryers
Remove front of dryer to clean lint from interior
open door remove eight screws, four on plastic guides and same location on hinges. wiggle door and it will remove . now grab narrow ends of front panel and pull toward you. wwhen panel gets to 45 degrees pull off tabs at bottom.
Jan 30, 2008 | Maytag MDE9316 Dryer
Whirlpool LER5636P Electric Dryer Logo
104 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
