Question about HP Photosmart M425 Digital Camera
Camera Locked The camera is locked and it says: Memory Card Locked. Have gotten two new memory cards and checked and rechecked the slider on the cards. Still says memory card locked and won't let me take pics. This problem has been stumping me for quite some time now.
  • busyb2000 May 10, 2008
    Having the same issue as "sycamoretree". It's not a problem with the card, since I've tried two other cards that are working in my other camera. Problem occurs once any of the cards are inderted into the slot in the M425. I am also unable to get the format capability. Stumped!
    Novelist:
  • 142 Answers
Many times you need to format the memory card in order to use it... have you formatted the memory card? There's a menu on the camera to do this.
If you're using a card like an SD card, there's a very small slide switch that actually locks the card so no one can over write your pics. Find the slide switch and move it the other way, and that should unlock the card. You'll still have to format.
Posted on Mar 18, 2008
SOURCE:
After setting memory card, showing 'memory card error' in camera screen and then showing 'memory card locked'. Please email me for unlocking procedure. Thanks.
The camera have to format the card
before you can use it.
There is a slider on the card.
Try to move the slider so the card is
not write protectet.
Look in your cameras manual
for the settings of formating a card.
Good luck.
Feb 24, 2011 | Kingston 4GB Secure Digital High Capacity...
Card locked
An SD memory card usually has a little white slider on the outside of it. I says in small letter, with a little arrow "LOCK" . Push the slider in the opposite direction of the arrow i.e. to unlock it.
If this is the case, then the camera should be able to communicate and write to the card.
There is also the possibility that the device in the camera which detects this slider is damaged. In that case the camera should be repaired. I think, though you will be OK moving the slider.
There is also the possibility that the card is corrupted. See the Link below
http://www.normsoft.com/kb/idx/49/157/article/
I hope this has helped you.
Happy New Year,
Best, Mark
Jan 01, 2011 | SanDisk 2GB microSD Memory Card
The camera tells me the memory card is locked!
If it is an SD card then there is a small slider to lock and unlock the card on the side
Apr 25, 2010 | Praktica SlimPix Digital Camera
My memeory card is locked
On the side of the memory card, there is a small slider that locks and protects the memory card from being overwritten. Yours may be in the locked position. Simply pull out your memory card from your camera and unlock your memory card by sliding the tab.
Hope this helps,
Andrew
Do not forget to vote.
Apr 10, 2010 | Casio Exilim EX-S600 Digital Camera
Memory card is locked. Where is the lock?
This is usually caused by the SD card, and is nothing to do with the camera. On the SD card there is a small slider - which allows you to lock the card (to prevent accidental erasure).
If you put in on the table with contacts upwards, corner cut top left, then the slider is on the right hand edge, about 1/3 the way down. If it is slid to the top position (nearest the contacts) the card is unlocked. If it is slid down (away from the contacts) the card is locked.
If it is a damaged / "cheap" card, sometimes the slider falls out, in which case the card is locked. You can still read from it, but not write to it until fixed or replaced.
First check is to turn the camera off, remove the card, move the slider to locked, then back to unlocked. Replace in the camera and turn on.
Mar 02, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My camera says my CARD LOCKED. how do I change
Hi!
You need to take of the memory card off the camera. Inspect the memory card and look for a slider. The memory card is write-protected so you need to move it up if its currently on the bottom position. Reinsert the memory card into the camera and then do some tests again.
Nov 08, 2009 | Computers & Internet
Memory is locked on the camera
ok so on sd cards there's a slider on the side of it. this has an arrow (usually pointing down) that says lock next to it. make sure the slider isn't on the side that the arrow points to.
hope this helps ;-)
Apr 04, 2009 | Sanyo Xacti S650 Digital Camera
Memory card blocked!!
I have the same exact problem with my camera and NOTHING works. Bought a new card, didn't work. Checked and rechecked the card to make sure it isn't locked...didn't work. I have no solution for you but to tell you you are not alone with this problem and it isn't your card or the little slider on your card. It is within the camera.
Jan 24, 2008 | HP Photosmart M425 Digital Camera
Locked memory card
hi
the unlocking is due to digital camera and not due to card. card do not have any locking feature. checkup on camera password
or alternately ask replacement fm company as this as 5 yrs warranty
Jan 20, 2008 | SanDisk Memory Media
Memory card locked
Hi everyone,
Here's the solution, I just had the same problem LOL!
1. take the memory card out
2.On the memory card there is a little switch (it will be the little tiny piece on the side of the card thats a different color) slide it up.
That's it!
Bye
Nov 05, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
HP Photosmart M425 Digital Camera Logo
373 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
