Question about HP PSC 1610 All-In-One InkJet Printer
Phantom paper jam
Whenever I try to print something, it will feed the paper through to a certain point, and then stop--literally for no apparent reason--and say that there's a paper jam. I open up the back, clear the paper, and try to print again, but the same thing happens.
I've tried the basics, like unplugging up and plugging it back in again, but to no avail. I've also tried re-installing the ink cartridges. The only other solution I see is to re-do the set up.
Can someone tell me if there's an easier or more effective option?
I'd really appreciate it. Thanks.
PS: It should also be noted that I've found nothing blocking The paper inside the printer. There seems to be no physical problem whatsoever.
"There is no spoon"--The matrix.
  • mr9000 Mar 18, 2008
    Furthermore, When the paper is stuck at that point, and I press the 'OK' button, it feeds the paper through (but doesn't print anything on it.)
    Thanks again for your help
    "There is no spoon"--The Matrix
  • rhedize Apr 24, 2008
    have exactly the same problem,
    enormously frustrating,
    tried everything but not the paper feed cleaning kit,
    would this work though ?
    feed seems to be okay & the paper freezes at exactly the same place each time ?!?
    Novelist:
  • 188 Answers
Hi Sir,
The problem is with rollers of the printer. Please perform the steps provided in the web link given below, this might fix the issue else you need to order a roller cleaning kit, if your printer is in warrent and you are from US. You can get it online.
Here are the links:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=us&lc=en&dlc=en&product=390315
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00744840&cc=us&lc=en&dlc=en&product=439488
This will fix the issue.
Posted on Mar 20, 2008
Error paper jam
Hello Cassandra,
It sounds like you are having phantom paper jams. When the printer starts a print job and tries to pull a piece of paper but can't grab it the printer thinks there is a jam but there really is not. If the paper pickup rollers are worn down they are not able to grab the paper correctly to feed it into the printer which causes this type of error. The rollers are considered user installable and come in a kit with the rollers and the paper separation pad which keeps more than one paper from being pickup up at the same time. Installing the paper feed kit should clear up your paper feed problems. The paper feed kit is available here: http://www.ccl-la.com/catalog/product_info.php?products_id=342
I hope this helps.
BuddyMc
Aug 06, 2013 | HP CP3525N Color LaserJet Printer
Paper jams on left side of printer and will not feed through
You have almost certainly got a foreign object in the paper feed path as there is nothing on the L/H
side that could cause an obstruction. First of all turn the printer off & disconnect all cables. Turn
the printer upside down and give a good shake, with luck the blockage should fall out. If not then you need to be a bit brave, make sure the print carriage is parked fully right and out of the way. You will need an A4 (approx) sized piece of stiff cardboard such as the backing from an A4 note pad. Insert this into the paper feed locating it between the feed rollers on the R/H side. Then push quite firmly to overcome the spring pressure, when you feel it push through about a half inch stop and open the printer to see what is being pushed through. Push the card fully through and retrieve the foreign object (I have found everything from paperclips, curtain hooks and even a golf tee!). Push the card through fully and out of the printer. Always remove paper jams etc, in the direction of the paper feed whenever possible
as pulling anything backwards can dislodge or break the sensor flags.
Hope this helps. Please take a moment to rate this solution, thanks.
Apr 08, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Paper feeding halfway through then stops
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Samsung CLP 300 Laser Printer
Paper tray feed problem
the shaft the roller is on is bent or the clutch on the left of the shaft iis broken.
Jan 02, 2009 | Samsung ML 1510 Laser Printer
Paper Jam
Seems you have a dusty roller in the feed mechanism. try cleaning off the roller with some windex (or equivalent) on a towel.
Nov 18, 2008 | Brother MFC-9420CN All-In-One Laser...
Jam...
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jul 17, 2008 | HP DeskJet 940c InkJet Printer
MP600 Paper Jam
I just had the same problem, tried everything and resigned myself to buying a new one. I was about to throw the thing when I saw the Card backing of an A4 Pad. I thought I have nothing to lose so forced this through the machine and Bingo. It cured it.
Jan 17, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam, when there's not a paper jam?
there is a small micro switch , when paper is loaded that switch
is activated, bent switch, paper shreds jamed in switch, will cause paper feed problem.
Jan 13, 2008 | Lexmark P4350 All-In-One InkJet Printer
Paper problem
At this point, you my wish to try feeding a slightly thicker piece of paper or light card stock through the printer. If that fails and there is no obvious paper jam then I'm afraid there is nothing else and the printer would need to be serviced or replaced.
Sep 09, 2007 | Epson Stylus CX5200 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
56 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
