Question about GE JBP70SKSS Stainless Steel Electric Kitchen Range
FOOD AND DUST BETWEEN THE GLASS
I need to know how to take apart the oven door to clean between the panes of glass. Seems like a crazy thing to pay a GE tech for as this is what they recommend.
    President:
  • 778 Answers
Hello MotoMom,
I have disassembled an insulated door with laminated glass to clean between the layers of glass once and will never do it again (as it took far too much effort and time).
I will suggest trying to get a fair flat rate (not hourly) for completing the task to your satisfaction, guaranteed for at least 1 year. I would also check with other appliance repair shops/technicians (other than just the GE authorized repair), unless it will void any warranty the oven may have.
I hope this helps you, and good luck.
Posted on Mar 18, 2008
How do i remove the glass from the door
The oven door glass panel is a sealed unit that is not intended to be removed for "cleaning". The unsightly residue between panes accumulates because the metal seal expands while the oven is heating.
Jul 30, 2016 | Ovens
I have Omega wall oven model 00652xb 6yrs old, there are dribble marks in between the glass in the door. How do I clean it. I can't see how it comes apart. Thanks
The oven glass is a sealed double pane. it is not designed for removal, separation, cleaning, and reassembly.
May 12, 2016 | Ovens
How do I clean inside double panes glass in oven
the door will have to removed and taken apart. Different stove ovens doors come apart differently. be careful and lay the door down on a sturdy surface when taking the door apart.
Oct 04, 2014 | Ovens
My self cleaning kenmore stove seems to have grease between the window panes on the door. cleaning doesn't reach this problem. i need to get between the panes to clean them - how can i do this? will...
Taking the door apart is relatively easy and unfortunately the only way to clean between the two pieces of glass. All you need to do is remove the screws holding the outside cover on.
Jul 01, 2011 | Ovens
I purchase the Whirlpool electric double oven range GGE350 almost a year ago. The problem I have is with the oven door. There is evidently spillage or something between the glass pane. How is cleaning...
Hello, Thank You for using FixYa. I will be helping you today.I would recommend paying for a service call to have a tech take the door apart for you. There are four pieces of glass in the door and lots of screws. It really is a pain to take doors apart we as techs get this call all the time. Believe me you will thank me you paid someone to do it. If it were easy i would tell you. Most people take them apart then end up paying because they cant put it back together.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Whirlpool RBD305PD Electric Double Oven
THE GLASS ON MY OVEN DOOR IS STREAKED. CLEANER/CONDENSATION HAS GOTTEN UNDERNEATH GLASS. DRIVES ME CRAZY LOOKING STREAKED. ANY SUGGESTIONS? THANKS
usually there is some way to take either the handle off of the door, or take the door apart from the inside and you can seperate the parts of the door and remove the glass and clean it and replace everything back.
Jun 22, 2010 | GE Profile JTP18 Electric Single Oven
Oven glass
all oven doors collect grease to some extent, depending on which pane of glass actually got dirty will determine how difficult it is. your owners manual shoudl describe how to remove the oven door, after that, layont it o nthe table and carefully reomving the screws from along bottom panel you should be able to ge tto your dirty glass, might take a few screws, just dissasmble slowly, dont overtigthen screws and above all remembrer how your taking apart for reassmbly
May 03, 2008 | Whirlpool RBS275PD Electric Single Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Outer glass needs cleaning
yes. open door slightly to first stop point, pull up on door. the door will come off. there are screws on the bottom of the door and on the side facing the inside of the oven remove these screws to take door apart
Nov 18, 2007 | GE Profile JTP18 Electric Single Oven
GE JBP70SKSS Stainless Steel Electric Kitchen Range Logo
171 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
