Question about Toshiba 2060 Copier
Paper Jam A Toshiba 2060 Copier was donated to our organization. We have tried to copy, but the paper keeps getting jammed in the fuser. What is the solution? Apparently this machine hasn't been used for over a year.
  • 168 Answers
1st, you need to find out exactly where the paper is getting stuck.
Is the paper stopping just as it gets to the rollers, or
stops when it goes through the rollers and are getting stuck on the little fuser claws?
If the paper is stopping right when it gets to the rollers, then there is a problem with the fuser drive or drive gears.
This you would probably need to place a service call to have repaired.
If the paper is getting stuck in the claws, then make sure that the claws are not stuck down. All claws should be up against the rollers, both upper and lower claws.
Sometimes they get stuck down or the spring gets knocked off.
Other than that, as long as both upper and lower fuser rollers are in good condition, paper should pass through.
If you have any other questions, feel free to repost.
Good luck.
If I have helped answer your question, please remember to post a rating.
Mac =)
Posted on Mar 19, 2008
Toshiba 2060 gives Misfeed error. The copier is not picking the paper up out of the tray. There is no jam. What's going on ? Is there an easy fix?
sounds like the paper feed rollers are worn or dirty try cleaning the rollers if the problem persists then unfortunately you will have to replace the rollers
Apr 06, 2011 | Toshiba 2060 Copier
Toshiba 2060 copier shows paper jam at right side but I can not find any paper jam at all any other thing will cause to show paper jam? thanks mike
sometimes it does not sense that you opened the door that it says the jam was in. open and close the jam areas to see if it clears. if not restart the copier
May 17, 2010 | Toshiba 2060 Copier
Canon imageRUNNER C3200 Copier troubleshooting paper jams. The copier will jam, i will removed the jam paper for i can have a fresh start. i will try to copy again and the paper will jam again. can any one...
It could be a few different reasons the printer is jamming.
The pickup rollers could be worn; There could be an obstruction in the paper path the fuser could be bad
It all depends really on where the unit is jamming (Ie where you have to take the paper out from)
If the copier starts to work, and then gets an error but no paper travels into the unit the pickup rollers are the likely culprit.
If the paper stops somewhere in the middle of the copier, then an obstruction within the paper path must exist or some other internal failure.
IF the paper jams at or in the fuser then yes the fuser is the problem.
Hopefully this helps and feel free to add another comment with more info or questions :)
Sep 03, 2009 | Office Equipment & Supplies
Paper jam on my toshiba 2060 model
Exactly where in the machine does the paper jam??If it jams when you hit the print button, try cleaning the paper feed tires with WD40.spray it on a clean cloth, clean the feed and pickup tires thoroughly and make sure to get ALL of the WD40 off the tires before using the machine.If you take the paper cassette out and look with a flashight you should be able to identify the paper feed tires.
Mar 24, 2009 | Toshiba 2060 Copier
Toshiba 2060 jams (accordion/fans the paper) at the fuser unit. Torn Paper now stuck next to the roller/drum and now jams every time. How do I remove the torn bits of paper to keep it from jamming?
sounds like a broken fuser drive gear.The fuser operates a nearly 400 degrees Fahrenheit and the drive gear cracks and falls off.Lots of trouble for a 50 cent gear.They are mad of fiber or plastic.take a few of the covers off near the fuser and disconnect the cables and the fuser slides out
Jan 11, 2009 | Toshiba 2060 Copier
Paper Jam
Some basic non-tech questions:
  • Are you using paper that's been allowed to sit open for weeks? It might have absorbed water.
  • Are you in the habit of reusing paper that's double-fed? I used to, but it's more likely to jam
  • When was the last time the technician was in to do a preventive maintenance? The machine may need a basic clean-and-check.
  • Check your manual, and check what the machine is telling you (on the display, if it has one). The location of the jam may give you an idea of the reason for the jam (jamming at the fuser may indicate a cold fuser, jamming at the drum can be caused by broken separation fingers, etc.) If you have a technician, this will be useful information.
Nov 22, 2008 | Toshiba 2060 Copier
Toshiba 2060 Paper Jam at the fuser
I would have to say that you are missing the fuser drive. I would remove the fusing unit and look to see if you are missing any gears or any missing teeth from a gear or just missing a gear...
Jun 18, 2008 | Toshiba 2060 Copier
Landscape copies get stuck
The roller may have something stuck in that area, something even as small as a peice of paper can continue to make it jam. if not, you may have to call the company to get a repair guy in... umm... or repairGirl?
May 17, 2008 | Toshiba 2060 Copier
Paper misfeed
hi im jules_09.have you check the inside of the copier?open the front door then see if there a paper in the transfer the transfer is in front of you if the door is open.the check the fusing unit many paper jams happen in the fusing unit.then at the paper tray if you cannot locate the paper jam inside the machine look at the paper tray from 1 to 3.then at the side most copier have opening at the side look for the door so you can see if theres any paper stock
Nov 22, 2007 | Toshiba 2060 Copier
Jaming on copier
there is the problem in the heater unit of your machine check it,open the front cover release the blue lock left side and take out the paper
Sep 11, 2007 | Toshiba 2060 Copier
214 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
