Kenmore top load washer #110.26912691. During the spin ycle, it sounds ss if it is off balance even when it is empty. the shsking is not as bad as in a "real"unbalaned, what can I do????????
Recently, the "LF" code has started to display and the soak cycle will not complete unless I ... Kenmore Elite Top Load Washer - Unbalanced Loads During Spin Cycly ... Would a bad outer tub literally cause the basket to become unbalanced?
? 1:21
https://www.youtube.com/watch?v=cVZIGhULzg0
Jan 17, 2014 - Uploaded by Carpe Diem
How to fix unbalanced high efficiency top load washer. ... I am having a MAJOR problem with unbalanced ...
If you balanced the machine, the only other problem could be the load itself. Either the load is too great or if washing a single item its falling to one side, tilting the drum and when spinning it will thump. Try even lodes.
souns like the gearbox (what the motor mounts to) it bad. I'm asummin the load in the washer is balanced (all the clothes are not on one side of the tub)
to cause unit to go off balance taking in fact that you put clothes in washer even...check your counter balance spring it hold the tub to base at rear of unit,,,and check your balance ring at the top of your wash basket its fill with water if cracked will cause this problem,,
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
