Question about Zanussi ZX99 / 5 Bottom Freezer Refrigerator
Bulbs and bottom pcb blew, replaced but still not working
The fridge blew both bulbs, and tripped the main fuse for the ring mains, replaced the bulbs and reset the fuse. fridge still not working, checked the socket and replaced the plug fuse, still not working, checked the power control board at the bottom rear and found that had also blown, replaced that too using the serial number to get the right part, but this has not solved the problem either, ive check the top board that has the led's and temp dials on but that looks to be ok.
is there anything else i need to check or that could be the cause of fridge/freezer not working?
thanks
  • mikegsi Mar 25, 2008
    that sounds like it could be the cause, can you tell me where to find this capacitor?
    cheers
    mike
  • Anonymous Mar 20, 2014
    The top line in the second 88 flashes.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 32 Answers
The start and run capacitors of the compressor can go short circuit and cause a big spike that can blow the bulbs, trip fuse etc. Inspect the capacitors for splits etc, you may well find that the start cap has blown and so there will not be enough current to get the compressor running.
Posted on Mar 19, 2008
  • tony denham Apr 03, 2008
    the cap / caps will either normally be bolted to the side of the compressor or in their own box + maybe with a relay in there as well, if the relay is not in a box then will be attached to the compressor. The relay may be burnt out and also could be inoperable and or stuck in one position either start or run. If you follow the main power wire from the compressor ir should lead you to the capacitors. If they are ok you could try putting a meter accross the compressor windings to see if they have gone open circuit also.
An Amana fridge SRD520TW has started tripping the house's main circuit board.
The start capacitor on the compressor may have failed. There is a chance that a defrost heater element has shorted to a metal part of the fridge.
Aug 13, 2016 | Amana Refrigerators
Trip switch cuts out when i use washing machine
Main board power circuit fault.disconnect main PCB and reconnect power cable .you can identify the fault. Replace main pcb.
Sep 01, 2014 | Indesit Washing Machines
Tripping electricity
HI, The reason for the over-pull is due to the unstable conditions located at the main PCB that controls this affected unit. The voltage is not stable, due to the damage located at the PCB(circuit instabilities). Just to be safe, have your local electrician inspect the breaker box for shorts and damage to the appropriate circuit block. If the electrician confirms that the breaker is in good condition; replace the main control board(PCB) that is mounted near the compressor or behind the rear access panel.
Jul 21, 2010 | Whirlpool Freezers
Athena AS-P4100 Sub Woofer - blown main fuse - who repairs these?
Sorry I can't solve your problem. I think the main fuse on mine is blown too. Can you tell me where it is located?
Mar 09, 2010 | Athena AS-P4000 Subwoofer
Miele bottom freezer / fridge. Main control panel
Electronic is about 150 pounds plus vat
Ring Miele in UK on phone number below.
01235 233133
Jan 10, 2010 | Miele KF7642S Bottom Freezer Refrigerator
Oven tripped fuse and will not turn on
Hi!
If the oven is not working, you need to check the fuse on the main PCB - If the fuse is good check for continuity between the fuse and L3 (drive motor terminal) - If this circuit is open the PCB is bad and must be replaced. When re-assembling please be sure all the wiring is correct.
For your reference, you can check the following link---
Dacor Epicure Electric Oven Technical Manual
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 31, 2009 | Dacor ECD230 Epicure Electric Double Oven
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Dryer trips the fuse box
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
THE MAYTAG fRIDGE/fREEZER BLOWS OFF I.E. IT SWITCES ITSELF OFF AND THE MAIN FUSE TRIPS OFF. THE PLUG FUSE NEVER BLOW OFF THOUGH.AFTER COUPLE OF DAYS,WHEN WE PLUG IN THE THE FRIDGE/FREEZER IT WORKS FINE AND...
what's the model number,i don't understand what you're asking,are you saying the fuse keeps popping in the house fuse panel?or the fridge stops running and the house fuse is ok.what is i.e.
Feb 07, 2018 | Maytag Refrigerators
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Zanussi ZX99 / 5 Bottom Freezer Refrigerator Logo
341 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
