I was given a "Wireless-N Home Router Model #WRT150N as a gift. I have an Aser Aspire 7520-5971 laptop. I have arrange for Road Runner service to my home to which I plan to use the above defined router. Do you see any problems using the combination? Also do you have any suggestions or things I should know to make the installation easier? The Router was purchased from Circuit City on 10/15/07. Any help would be appreciated! Thanks for your help, Chuck Wilke
    President:
  • 778 Answers
Hi Chuck,
Sounds like you got a pretty nice Linksys router, and I don't see any compatibility issues for it's use with Road Runner's modem or your computers that will connect to it. Your router came with an installation guide with step by step diagrams and if you follow the directions you should be just fine.
Note that the "N" router will work with previous/slower WiFi such as wireless "B" & "G", but if you want computers on this network to utilize the speed that the "N" router provides they will have to have "N" cards or dongles.
I hope this helps, and Good luck.
Posted on Mar 18, 2008
SOURCE:
Service Hook-ups...
1- in order of what connects to what
1- linksys connects to road runner modem. Should be a network connection on the back of the router that says uplink. This connects to the road runner`s wired port on the back of the unit.
Vonage phone will/should connect through the wireless section an in your personal wifi connection when you get the router wireless setup. Name your wireless something that other people are not using and then tell vonage phone to connect to that network.
Hope this helps
Feb 16, 2014 | Linksys E3000 Wireless Router
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
Need help, router will not connect. The internet service road runner is working when I plug directly in computer but through the router it won't activate. This router has been working for over a year now...
Try unplugging the power from Road Runner modem and disconnect the computer or router. Then only plug in the power to the router and plug in the power to the modem.
If this does not work, try resetting the modem's config to factory defaults by sticking a paperclip end into the reset button hole in the back while powering it up. hold the buttin in for atleast 15 seconds while the router restarts. then retry the first suggestion.
Jun 01, 2010 | Linksys Wireless-G WRT54G Router
No internet connection
ok
check on back side of router then u see reset button press it for 10 seconds then it restart and also reset all settigns to defaults.then u have to reconfigure it,
u cna access your router with one of the following lionk
http://192.168.1.1
or http://192.168.0.1
type useranme as "admin" and pasword as "admin" or blank
May 09, 2009 | Linksys Wireless-N WRT150N Router
Linksysy asks for a network key (Wep key or WPA key)
1. Using a computer that is wired to the router, access the router's setup page by typing 192.168.1.1 on the address field of your browser.
2. By default there is no username and password is admin.
3. Once you're in the setup page, click wireless then there is a sub tab there called wireless security.
4. You will find there the wireless key that is enabled in your router.
Nov 08, 2008 | Linksys Wireless-G WRT54G Router
I need to set up a home deaktop computer to intranet and share files/folders with wireless (netgear router) with my toshiba laptop and still be able to access internet through time warner road runner...
you can set that up. all you need to do is manually configure your desktop which is connected to that router and have your laptop receive signal from your router...
Apr 20, 2008 | Computers & Internet
Router
I usually don't use the software, I use the default IP address of the router to log into the router and set it up. Manual
to enter the routers utility,plug the pc/laptop into the router with the cat 5E cable, open the browser, type in the routers address,
192.168.1.1 User is blank password is Admin.
software.from this link, choose which wrt54g you have version 1-7
Apr 01, 2008 | Linksys Wireless-G WRT54G Router
Can't connect wireless to WRT150N.
Your hardware might not be compatible with eachother.
Mar 17, 2008 | Linksys Wireless-N WRT150N Router
Not working on my 2nd computer
I am going to assume Vista is the first OS and both machines are windows computers and you are accessing the cable service through a DI-524 wireless router. There are many issues that can relate to your problem. First does your cable provider require you to logon to access the internet. If so, try using each computer individually (with the other one logged off and shutdown) with the existing wireless connection. If this works both machines are configured correctly for the router and the issue appears to be dealing with the logon possibly having it performed by the router if possible. Second if that does not work -- on each machine bring up a command prompt window (Start > All Programs > Accessories > Command Prompt) and type ipconfig and press enter. There may be multiple local area connections but look for one with a 192.168.?.? address on each machine. The first question mark should be the same on both machines and the second different. If this works both machines have connected to the router and we are seeking another issue. If this is not true one machine has a configuration problem and cannot access the wireless router (probably the Windows ZP computer from you description). We will need to diagnose further once you answer the above questions.
Dec 05, 2007 | D-Link AirPlus DI-524 Wireless Router
Open Questions:
AOL MAil TecHNicAL {1.855.536**5666}#[email protected] SuPPoRt HELP DESK This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 21, 2019 | AOL Computers & Internet
AOL MAil NuMbER {1^855^536^5666}#[email protected] ALABAMA This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Computers & Internet Logo
97 people viewed this question
Ekse
Marvin
Marvin
