Question about Sewing Machines
Feed dogs the feed dogs won't raise manually or electricly the feed dogs on this machine will not raise high enough and the machine sits sewing in one spot
  • 10 more comments
  • Anonymous Mar 22, 2008
    Trying to do free motion quilting. Can't figure out how to lower the feed dogs.No button and manual doesn't discuss feed dogs.Have been changing feet to help my situation.I have 6003 quilters dream.Any help will be appreciated.
  • Anonymous Jun 08, 2008
    nothing please help
  • Anonymous Aug 17, 2008
    it sucks i cant sew it drives me crazy!!!!!!!
  • Livelaugh Aug 26, 2008
    My material will not feed the switch on my (brother cs 8150) will not bring my feed dogs back up. Is there a part I can buy to fix it? I love my sewing machine and if I can fix this myself it would be great! Thank you for your help.
  • mmongold Aug 27, 2008
    The lever will not move the feed dogs. How do I fix? It is actually a 9110 model.
  • hollybeth Sep 12, 2008
    The feed dogs will not go up and down.
  • hansonsb Nov 17, 2008
    i can't get the feed dog to lower. I have tryed to do this by pushing the buttom on the back by hand and it looks like it is lower but when i start it tells me to lower the feed dog.
  • vacman1128 Nov 28, 2008
    I have the exact same problem the feed dog does not feed the fabric.
    but seems like it is moving
  • vlpetersen19 Dec 03, 2008
    The feed dogs will not raise or lower when the slider is moved. They appear to raise partway in the front but not the back
  • lmeierdirk Dec 05, 2008
    The feed dogs don't move the material at all. I moved the stitch length all the way up and they started moving and worked for a little while. Now it has stopped again and the only way to move the fabric is to pull it through.
  • wantab Jan 08, 2009
    what do you mean a feed mechanism that has dropped?
  • essencerose3 Jan 28, 2009
    I just bought my brother nx400 today. I got it home, took it out of the box, plugged it in... and immediately when I tested the feed dog lever, the feed dogs dropped down, but will not raise back up. It seems like this is a common problem because the floor model at the shop did this as well. At the time, I put it down to their floor model being used/touched a lot by customers, but now I know otherwise. I'm disappointed and rather upset!
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Posted on May 01, 2009
  • Theresa P
    Theresa P Mar 12, 2014
    Tried that and it didn't move up. Is there something else I can try before taking to repair shop?
Finally got my case apart. Had to remove all screws and apply pressure to inner plastic tabs that lock the case in place at several points. By plug area, at corners, etc.
There is a pin that rests beneath a plastic screw going through a bolt behind feed dogs. This pin then rests in divot on a white plastic piece (about 1.5" - 2" wide) above the lever to raise n lower the feed dogs. This piece is only visible after removing the case. The pin had slipped out of its little divot. I pushed it back into place and feed dogs now raise.
Used to get '88' error when trying to wind bobbin. Hope it fixed that, too. Won't know till I get it all back together. ;)
Posted on Dec 01, 2010
I just called Brother on the same problem.
Turn the handwheel to lower the needle
Move the feed dog level so its in the raised position (you can also do this before lowering the needle)
Keep turning the handwheel towards you to raise the needle and the feed dogs will rise with it.
Posted on Feb 03, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 43 Answers
Took the machine in to be repaired ... there was a part broken under the feed dogs. thanks
Posted on Mar 30, 2008
On the 2662 there is a switch underneath the removeable toolbox, the thing that you remove to make it a free arm; anyway there is a switch that raises or lowers the feed dog. ive had numerous machines and have never seen this, but its there.
Posted on Apr 19, 2008
    Problem Solver:
  • 14 Answers
Hopefully, you have the problem fixed by now. If not, if you bend over the front of the machine, you should see a slider switch on the back of the machine behind the needle plate. There is also a small button by the slider switch at the right end of it (your right). If you push that little button down, you should be able to slide the switch to your right, which will raise the feed dogs back up.
Posted on Mar 26, 2009
I have a Brother XL-2230. There is a white plastic plate in the accessory bag. Snap this over the feed dog to cover it, and it will give you free motion. By removing the foot, you will have the freedom just as it the feed dog was down.
Posted on Apr 02, 2008
Why when I sew the fabrics not advance even if the claws are raised and the machine does not stop sewing. I have to close the switch
With the issues you are experiencing, it may be wise to take it for service.
Even though the feed dogs are raised, are they actually moving forward and back as you stitch (remove the thread, raise the presser foot, rotate the handwheel, and watch the feed dog action)? Check that the stitch length is set long enough that the feed dogs will be moving the fabric rather than sewing in place. Another thing to check is whether there is a pressure adjustment for the presser foot. If you are sewing light weight fabric, sometimes the pressure needs to be increased so the feed dogs are able to grab the fabric.
As for the machine running on, it could be a multitude of issues, ie the foot control, electrical... This may be something that a professional should evaluate.
Jun 22, 2016 | Janome Memory Craft 9000 Computerized...
Singer model 518....the material won't feed through.It wants to sew but won't feed cloth through. Thks
Be sure you have the stitch length set high enough that the fabric will actually move instead of sewing mostly in one spot.
One other thing to check is the presser foot applying enough pressure to the fabric so that the feed dogs can grab the fabric? On the top left side of the machine, there is probably either a dial or a push-type button. That would most likely be the pressure adjustment. The tighter that is set, the harder the pressure the presser foot will apply and the more the feed dogs will grab the fabric.
Check that the feed dogs are in the "up" position so they will pull the fabric through the machine. Are the feed dogs actually moving forward, raising above the needle plate, pulling toward the back of the machine, and then dropping below the needleplate before moving forward again? If not, then the problem could be with the feed dogs.
Your machine appears to be a mechanical model. If so, it could be the machine needs a good over-all cleaning and oiling--a couple drops of fresh, good quality sewing machine oil every place that metal rubs on metal (no plastic parts, belts...). Feed dogs are frequently affected when the sewing machine does not receive regular maintenance.
Jun 04, 2016 | Singer Sewing Machines
Feed dogs up?
If the feed dog lever does not raise the feed dogs, then they are probably stuck. Probably needs lubrication. Since the make/model was not specified, would recommend taking it for service.
May 11, 2016 | Sewing Machines
My feed dogs will not pull my material through.
Check to be sure you have not inadvertently dropped the feed dogs on your machine. Dropped feed dogs are used for 'darning' or 'free motion quilting.' Below is info from Troubleshooting Manual:
Fabric does not feed through the machine
The feed dogs are lowered. Use the feed dog position switch to raise the feed dogs. 81
The stitches are too close together. Lengthen the stitch length. 42
The wrong presser foot was used. Attach the correct presser foot. 179
The needle is bent or blunt. Replace the needle with a new one. 34
The thread is tangled. Use scissors, etc., to cut the tangled thread and remove it from the race, etc.
Apr 11, 2015 | Baby Lock Esante
Dog feet seem as if they are not raising high enough to grab material and move it back. It their a simple adjustment?
It could be that your stitch length is not long enough to sew in a forward direction. Embroidery/Sewing machines have a feed dog switch to raise and lower for sewing or embroidery.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 28, 2014 | Sewing Machines
Singer 758 model and the material is not feeding through the machine. Needle is only going up and down in one spot.
here is a link for a free manual, check to see if the feed dog lever is up in the sewing position, if the feed dog lever is down then try to raise it up. if it will not raise then the machine needs to be check to see what's wrong with the feed dog.
http://www.singerco.com/uploads/download/6dc4cd61b0c61a5fc13e60785f01d29199328059.pdf
Nov 18, 2013 | Singer Sewing Machines
Janome memory craft 10001 feed dogs are not high enough how do you raise them?
in the manual it should show where the lever is to raise the feed dogs
here is a link for a manual if you do not have one
http://www.sewingpartsonline.com/janome-mc10001-manual.aspx
Jun 12, 2013 | Sewing Machines
Feed dogs won't raise and lower on my memory craft 9500, how can I fix this problem?
when your machine on your machine movable arm pushing a switch liver which will raise your feed dogs you can do one thing when your arm moves to the normal possision just given your finger to the upside movable are you see one long switch bar is there just push and see machine feed dogs will come out actualy that action to be done by arm only,you call one MC expart to resoved your problem permenetly.
Apr 21, 2012 | Janome Memory Craft 9500 Computerized...
Kenmore model 158 15510 will not catch the material to advance it while sewing. The catch plate does not go up high enough.
Feed dogs.
Check the manual for how to engage/raise the feed dogs.
Or, it could be the machine needs cleaning.
Open the bobbin area and the throat plate (plate under the presser foot) and clean with a soft brush or cotton swab.
Apr 25, 2010 | Sewing Machines
ELNA 7000 SEWING MACHINE
If the darn setting is selected the feed dogs will not rise, someone has probably inadvertantly selected darn.
Mar 18, 2008 | Sewing Machines
Sewing Machines Logo
2,664 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
