Question about Samsung HCM4215W 42" Rear Projection Television
TV Screen Randomly Goes Dark with Red Image
I am using my Samsung HCM4215W in "component" video mode (RGB) for both my DVD and cable connections (I have 2 separate component video inputs)
Regardless of the input, my TV from time to time goes dark with a residual red shadowy image. So far, it generally recovers in a few seconds, but sometimes it stays that way for a few minutes and then recovers.
I've run the auto-focus feature and that seems to run okay when the TV has recovered. I've tried running the auto-focus feature when the screen goes dark and it cannot complete the full cycle of tests (gets to about 25% and restarts the cycle)
Any suggestions?
  • tanyasoholt Sep 22, 2008
    I am having the exact same problem with a 4-year-old Mitsubishi WS-65313. The screen looks perfect and all of a sudden goes dark with a red shadow-like picture. If I have the patience to wait it out, the screen returns to normal. This is happening more and more often with longer recovery times. I'm afaid that there's a simple solution that I don't know about, or if I have a tech out to fix the problem, it won't happen while they're here.
Get a new tv
Posted on Jun 11, 2008
Samsung DVD-V3650 DVD Player / VCR Combo no sound when connected via component cable
Component connections between your DVD player and TV (they will be colored red, blue, and green) carry video only. You will need to connect two more cables for left and right audio channels. The connectors for these audio cables will be colored white and red for left and white respectively.
Nov 04, 2017 | Samsung DVD-V3650 DVD Player/VCR
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
The coax input on my tv is broken off how can I connect the cable to it other than the red white and yellow cords which don't have a good connection either I have my dvd player hooked up to hdmi is there a...
the simple answer is no.
but if you have basic cable (coax) you could connect it to a vcr, tune the channels with the vcr-
connect the vcr to the TV with composite video (yellow, red/white)
Apr 13, 2011 | Samsung Televison & Video
How do I attach my dvd to the 42 inch tv to watch a movie? Do I just attached the RGB connections?
An HDMI cable is best however a set of Component cables will also work. The Component (RGB) will also carry a high def image. You will need five cables in all. The Red, Blue, Green for the video and two additional RCA cables for audio (red and white). Color match the inputs to both the DVD and the TV. Select "Video" source from the Input menu of the TV. Confirm this worked.
Jul 01, 2010 | Haier HL42R 42 in. LCD TV
Y/Pb/Pr outputs are green; needs
There is no calibration for the component video that I know of, check your cables you may have a bad Pr cable or the Pr/Pb ones may be mixed up.
Y (the green one) is for luminance, plug in ONLY this connector and you should see a black and white picture.
Now connect the Pr. You will now see red tones.
Now connect the Pb. And you will see blue tones.
Reverse the Pr and Pb and see what happens.
Oh and make sure you don't accidently have one plugged into a composite video or digital audio port.
Still not looking right?
Go into the input menu of the TV and change the component (or colourstream) input from RGB to Y/Pr/Pb. (most TVs do not have this feature.
Hope this helps!
Jan 24, 2010 | Samsung SIR-TS360 DirecTV DTV Receiver
Trying to hook up the dvd player to the tv and I figured out how to get the color back on but the sound is terrible it sounds like its echoing. Can't figure out the blue green red combination for white red...
Your TV probably has several different ways of connecting video. One is component, which uses three cables. They are red, green, and blue (RGB). The video output on your DVD player will match this color scheme.
Another scheme for video is composite (because it combines the red, green, and blue into one cable). Composite video is usually a yellow "socket". It is simpler to connect, but the video quality is noticeably poorer than component (RGB).
Another scheme is S-Video. This is one cable (round and black), but you will see four pins inside the connector (and four holes in the "socket"). This accounts for the three cables in the component scheme with the convenience of having only one cable. The picture quality is almost as good as component as well.
In your case, there may be confusion between composite and component. If you have red, green, and blue sockets on both the DVD and TV, then make sure you use them and connect them color for color.
Now for the sound, this is simpler. Red is the right channel, and white is the left. Make sure you connect red to red and white to white. Then, viola, everything will be right.
I hope this helps.
Aug 24, 2009 | Philips Televison & Video
How do i hook my dvd player to my tv? i have no manual to show me where to plug the wires into the back of my tv.i have a proscan 32LB30Q LCD
Hello pebbles12137,
This depends on what you want to do SD or HD
First if you just want to connect for SD only
Here are Three ways:
1) connect the coaxial cable to the DVD player F-connector (sliver screw connector) and the to the TV's Antenna in F-connector.
2) connect the yellow, red and white RCA connector end wires to the yellow, red, and white RCA Jacks of the TV Yellow (video in), Red (Right Audio in), White (Left Audio in) do the same for the other end into the DVD player (Best SD Method)
3) connect the svideo cable into the s-video socket of the TV and the other end to the s-video socket of the DVD player
For HD, Here are the connection methods:
1) Connect the HDMI cable to the HDMI in of the TV (HDMI1)and the other end of the HDMI cable into the DVD player. (best HD method)
2) connect the Component video cable (RGB) into the RGB sockets of the TV (should be marked as Component 1) and connect the other end to the DVD player (using this method you will have to connect the Red and White audio cables to the audio input jacks of the TV from the audio out of the DVD player)
These are the SD and HD methods.
I would suggest using the HDMI cables only, its the best choice and the simplest.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 21, 2009 | Proscan 32LB30QD 32 in. LCD TV
Denon DVD-1740 component video to RGB cable
YOU HAVE THE RIGHT CABLES FOR THIS INSTALL, GREEN, RED, BLUE FOR COMPENENT VIDEO AND RED AND WHITE FOR AUDIO UNLESS USING THE OPTIACL OR COAXIAL, FROM THE DVD PLAYER TO THE AMP OR TV.
ON THE FRONT OF THE DVD PLAYER IS A HDMI BUTTON PRESS THIS BUTTON UNTILL OFF IS DISPLAYED AND YOU SHOULD HAVE PICTURE
Jun 02, 2008 | Denon DVD-1740 DVD Player
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Samsung HCM4215W 42" Rear Projection Television Logo
195 people viewed this question
Jerry Greenberg
Jerry Greenberg
