Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Cannon ImageRunner 3300 streaking faxes/copies
Hello, we are getting streaked copies and faxes, and they keep getting worse. There is more than enough toner, so we know that isn't the problem. We have had the problem in the past, and had a repairman come out. To avoid a large bill we are curious to know if it's something we can fix on our own. Any feedback at all is grately appreciated. Thanks in advance.
First, do the streaks only appear on copies and faxes made using the document feeder? If yes, the thin strip of glass just left of the large platen probably has has a speck of dirt on it. The speck shows as a streak when the page scans over it. Clean with window cleaner, Viva towels and elbow grease. If you shine a flashlight on the glass its easier to find the specks.
If the streaks appear and you are not using the feeder tray, then call for service.
Posted on Apr 18, 2008
SOURCE:
Black streaks on copies
if the streaks are narrow and looks as "barcode", you need to replace the drum unit. C-EXV18 Canon Drum unit.
Hope that helps!
Sep 05, 2011 | Canon Imagerunner 1025IF Grayscale Copier
Hi, My Canon 3245 Imagerunner is streaking.
First, the streaks appears when copy from glass or adf, when printing or all?
Solution #1:
How many copies did you do from last drum changing? if over 80 000 copies, replace the drum unit.
-in case that streaks appears when copy and print
Solution #2:
If the streaks appears only if you copy from adf or glass, clean the glass and dry it out. Both glasses, narrow on left side beneath the adf/cover and glass for copy of original.
Solution #3:
If the streaks are wide and solid, with possible toner left overs, you need to replace fixing film.
Hope that helps!
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Paper has black streaks and gets worse with use
has the paper got black lines across the paper, if so you might need to replace the drum unit
Aug 26, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Constant Streaks
If the streaks only happen when using the document feeder, cleaning the thin glass strip on the left of the machine will help.
Mar 17, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Cleaning Area
Try dusting the feeder out with compressed air. Then clean the glass with a flat razor blade to get any stubborn gunk that glass cleaner won't get. then spray a rag with streak free glass cleaner and rub the glass strip several times. good luck.
Feb 12, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
266 people viewed this question
Clive
Clive
old marine
old marine
Ekse
