Question about Acer AL1717 17" LCD Monitor
LCD Monitor needs repair
I have an Acer AL1717 LCD monitor. Its Inverter and backlight needs replacement. Where can I get it repaired?
  • statehitter Dec 26, 2008
    I turned my monitor off for a few days while I was away from my home. I returned to find out that when I pressed the power button... I got nothing.. no light saying it was on.. no screen flicker.. nothing.. changed the power cord several times to make sure that was not the issue.. I use a dual monitor system so I just switched it to a single monitor with the monitor that works.. Any idea on what the inverter board would cost and where to get one?
    Novelist:
  • 138 Answers
I used to repair LCD monitor from Dell. It works for me. You might be using these following steps to examine what is the problem of your LCD monitor. After you turned PC on and monitor stopped working or went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image (Start menu), there will be a minor problem. This is because of CCFL lamps inside screen. Some of them were broken and it is very easy to replace. You don't need to do anything with the inverter board in this case. If you cannot see anything on the screen, there'll be some problems with inverter board. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 18, 2008
How do I repair backlight?
Repair: LCD Monitor Backlight - YouTube
? 6:06
https://www.youtube.com/watch?v=BTjH-jkuo9Y
Jan 30, 2014 - Uploaded by Heilman Hackatronics
This videos shows how to repair an LCD monitor Backlight. ... I've Samsung SA300 21.5 inch led monitor ...
How To Replace a LCD Backlight - Instructables
www.instructables.com/id/How-To-Replace-a-LCD-Backlight/
InstructablesHere are some simple instructions on how to replace a burnt out LCD backlight with a new working one to bring your LCD back to life. ... To get the the LCD screen and thebacklight inside, you must first disassemble the LCD housing; this is different depending on whether it is an ...
A (very) Simple LCD Backlight Fix - Instructables
www.instructables.com/id/A-very-Simple-LCD-Backlight-Fix/
InstructablesFix any broken LCD backlight with an ordinary light bulb and a dead CRT monitor.Broken LCD monitors basically come in three categories:1) Cracked LCD ...
Dec 30, 2015 | Samsung Televison & Video
My AL1717 monitor shows a flickering power signal (blinks off & on) but shows black screen and nothing else. Thank You
Most likely a problem with internal capacitors either blown or swelling or leaking. Can be repaired by replacing the faulty capacitors but recommended that this be carried out be a qualifed technician
Dec 30, 2010 | Acer AL1717 17" LCD Monitor
Acer 5515 backlight not working also bootmanager missing
You need to fix the boot manager problem first by connecting an external monitor to the laptop so you can see and do a system repair.
As for the backlight problem :-
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info
Aug 14, 2009 | Acer Aspire 5610-4648 Notebook
Acer 4520g minitor blackout
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 14, 2009 | Acer Aspire 3680 Laptop
Acer aspire 4720z model laptop having dim resolution of monitor
The fault could be a faulty CCFL lamp or inverter.
Check out
www.lcdparts.net
Jul 23, 2009 | Acer Aspire 4720 Notebook
SCREEN GOES BLACK AFTER A FEW SECONDS AFTER TURNING MONITOR ON.
More often then not, this is attributed to a failing Backlight Inverter. A Backlight Inverter, is a power board mounted below the screen that actually send power to the Lamp inside the LCD itself. Check to see, when it goes out if there isn't still some images faint in the screen. If this is the case take it to a local repair shop and have them order one and replace it. repair cost for this shuold be around 65-100 dollars.
If this helps, please rate my solution. Have a great day.
May 16, 2009 | Acer AL1715 17" LCD Monitor
ACER AL 1714 SM MONITOR
Hi...there,
Well...your backlight inverter are busted.... need replaced a new one or repaired it.
Oct 12, 2008 | Acer AL1714CB (Black) 17" LCD Monitor
Acer 17 inch LCD Monitor when turned on fades in & out & doesn't light up
Hi...there,
Well, that tell you that you got a busted inverter. Need replaced a new backlight inverter or repaired it... Have a nice day!
Oct 08, 2008 | Computers & Internet
Screen is black
MP3082,
It's seems your backlight inverter is burnt out... Need to replace a new inverter or you can repaired.
Good lucks!
Sep 10, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1717 17" LCD Monitor Logo
133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
